Classic Audi » Technical » Mech/Tech » Transmission » 6 speed transplant: upgrade or nonsense?
Old 08-07-09, 10:30 PM   #11
I don't understand ppls, who like powerful cars, which are built with only one purpose - for straight line. Audi by default is noise heavy and that's bad, but audi and some entusiasts are placing in B series cars V8 engines... Even R5 engine turns audi into "gostraightoutofthecorner" In the same time I think it isn't impossible to create B3/B4 with 2.0 16vt/1.8 20vt with 50:50 weight distribution and power, that wouldn't be much lower than any 2.2 20vt
Old 09-07-09, 01:13 AM   #12
Gaz
Gaz's Avatar
a v8 is a nice option, as i don't think its much different in weight to the 5 pot. and the v6 is actually lighter?
or have i got that wrong.?
(Edit: can't beat the sound of the 5 cylinder 10 valve tho.. )
Old 09-07-09, 10:40 AM   #13
FlyingDutchman
Just do it!
FlyingDutchman's Avatar
The other choice is look at a more modern engine implant. Not sure how easy as I've not seen it done, but a 1.8T lump would always be a good talking point at the pub!
let alone the 2.7 biturbo V6 lump!
Heh-heh, words like these make my eyes water... Budget-wise, however the option seems to fade away.Next Audi will be at least a decent 5 cylinder, though!
Thanks
FlyingDutchman is offline   Reply With Quote
Old 09-07-09, 07:25 PM   #14
crisarc
as i understand it the final 6 speed is the same as the 5 speeder, only have the extra cog mid range to play with, so good for laggy wr's/rs2[or should that read" non linear" power curves]?
Old 09-07-09, 07:26 PM   #15
crisarc
sorry [wine] final 6 speeed ratio same ashh 5 shhhpeeder.....
Old 09-07-09, 09:50 PM   #16
Gaz
Gaz's Avatar
so won't do anything for economy?
I was kinda hoping a 6 speed would give an 'extra' cog for cruising.
Old 10-07-09, 10:09 AM   #17
FlyingDutchman
Just do it!
My thoughts exactly. In this case however, I think that the manufacturer has made sure the overall balance is as near optimal as possible...Will rethink my moves, but wow, what a lot of usable info!!
Old 12-07-09, 06:49 AM   #18
If u have enough powerful engine, put there diesel gearbox
80q 1.8 K-jet upgrade? 5-E Engine 7 13-11-09 01:19 PM
Engine transplant Tim C General Chat 0 30-10-09 06:05 PM
CQ Brake upgrade? Gaz Suspension & Brakes 5 27-09-09 04:34 PM
80/90 quattro transplant 10v turbo moggies Engine 8 26-03-09 06:51 PM
