-   Transmission (http://www.classic-audi.co.uk/forum/forumdisplay.php?f=30)
-   -   6 speed transplant: upgrade or nonsense? (http://www.classic-audi.co.uk/forum/showthread.php?t=5581)
FlyingDutchman 07-07-09 08:19 AM
I am making up a list (with a life of it's own) of things to do on my 1993 Audi 80 2.0 16v, as I believe in upgrading parts, not just replacing. This of course, makes life interesting to the point of madness..at times. I sense a lot of Audi fanatics experience the same, though.
Nonetheless, I have a question (1st of many).
Will the 6 speed gearbox fit my car? If so, where is the difference in gear ratios, from 1st through the whole range? What could the effect be performance / economy-wise?
(Sorry, it always starts with just 1 question...)
20vcqdriver 07-07-09 12:16 PM
Not sure with the 4 cylinder engines! If the block is the same as the later 4 cylinders you have a possiblity of doing this, but not sure.
Have all the info necessary if it was a 5 cylinder...:rock:
Coxy 07-07-09 12:26 PM
can't really see the advantages of fitting a 6 speed box to the 2.0l engine?
FlyingDutchman 07-07-09 05:41 PM
To be honest, after reading some feedback, neither am I, unless the power plant is upgraded as well, as some mentioned. Time to rethink!
FlyingDutchman 07-07-09 05:45 PM
Thank you, I will do some more homework on this, it seems as if I will have to rethink process and change powerplant to really get the benefit. I will keep you in mind should I stumble upon a 5 cylinder, which seems to be very popular and full of grunt!
Enjoy.
Coxy 07-07-09 05:53 PM
Unless it's the 20v or 20v turbo lump (S2/S2 avant), then you'll find the 2.0 16v engine on a similar par performance wise with the earlier 2.2 or 2309 5 cylinder 10v engines.
You just don't get the same grunt with a 4 cylinder engine though! Although a decent exhaust system would help that a little!
in fact, your engine should be 135hp and the 10v 5 cyl engines are 134hp.
FlyingDutchman 08-07-09 09:10 AM
Thanks, at least the collected info confirms that all of you are in the same line of thought, I have learned more in 3 days than in the same number of years with my GTX'es. The bigger engine=more grunt makes sense.
Much appreciated!:)
Coxy 08-07-09 09:14 AM
The other choice is look at a more modern engine implant. Not sure how easy as I've not seen it done, but a 1.8T lump would always be a good talking point at the pub!
let alone the 2.7 biturbo V6 lump!
vag80 08-07-09 05:51 PM
an 1.8t will fit in there easly,i think even a v8 may fit as the engine bay in the b3 and b4 is big
ChrisG 08-07-09 06:55 PM
several V8 conversions done in Europe, I've seen pictures ( a dark green series 4 comes to mind)
V8 into B2 4000 quattros in the USA.......silver one on Audiworld with loads of piccies of the various stages........ cannot find the piccies now I looked many months ago and they seem to have gone :(
