Classic Audi » Technical » Mech/Tech » Engine » Guage readings
Old 14-08-09, 08:15 PM   #1
vag80
vag80's Avatar
if it's an 8 valve thats normal change the rockercover gasket to a rubber one that'll stop it
200k club member
87-b3 80
83-4000 2 door
Old 14-08-09, 09:10 PM   #2
4v6
Engine oil of 1 bar at idles nothing to be concerned about as the engines not under any load, if however that situation was occuring at revs and load then id be worried, but yours sounds good to me.
Old 15-08-09, 12:38 AM   #3
irish80sport
irish80sport's Avatar
mine always sits at around 3.5 at idle and then off the scale at any rev. but i always wondered about my oil temp. it never moves only slightly above 60, im guessing its not working?
irish80sport is offline   Reply With Quote
Old 15-08-09, 02:33 PM   #4
Originally Posted by vag80 View Post
that sounds good as long as have over 2bar at 2000rpm your good
...but it's absolute minimum. My 3A iddling @ 1-1,1k [MAF potentiometr gone as usual] had something about 2 bar and 5k about 1,8 when fully warmed up. With worned out main bearings @ iddle were 1 bar.
However when I put the heater fan on full speed the oil temp guage rises and pressure guages drop considerabley. I guess there is a voltage drop somewhere but it did freak me out last week when I put the fan on to cool me down a bit then panicked cos I though the engine was about to overheat/run out of oil
What shows voltmeter in that moment?
If there would be not enough oil in engine [and that's about 1 liter below minimum!], pressure would fluctuate
Old 15-08-09, 06:04 PM   #5
the voltmeter drops too, less than 11 volts on a healthy 12 volt new battery.
Old 15-08-09, 07:32 PM   #6
W...w....what? Engine is running but u have 11 volts? How much is when your fan isn't running then?
Old 15-08-09, 07:59 PM   #7
when the fan is off then I have a good healthy 12 to 13 volts, good oil pressure and temp. When the fan is set at speed 1 or 2 then all is OK but when I select the speed 3 then the oil pressure and voltage guages drop and the oil temp goes up. It's a definate step change. I am not too worried, it's just a characteristic of the car
Oil pressure lamp and guage wayno Electrical problems 3 10-07-10 11:18 AM
temp guage irish80sport Electrical problems 4 17-01-10 11:53 AM
fuel and temp guage zxtrevr Electrical problems 1 04-10-09 07:38 PM
Audi coupe S2 temperature guage Darron Edwards Electrical problems 4 27-08-08 07:57 PM
