Classic Audi » Technical » Mech/Tech » Electrical problems » fuel and temp guage
Old 04-10-09, 07:02 PM   #1
zxtrevr
zxtrevr's Avatar
Default fuel and temp guage
got a couple of little problems
1 . the temp guage doesn't work at all.
2 . the fuel guage is a bit dodgy sometimes it'll be fine then you would go round a corner then it'll go into the red then come back up but it doesn't go right down empty.
just wondering where to start
94 audi 80 2.0 8v (B4 i think, my first Audi)
thanks Trev.
zxtrevr is offline   Reply With Quote
Old 04-10-09, 07:38 PM   #2
Darron Edwards
Darron Edwards's Avatar
Hi Matey, I had a problem for years on my S2 with the temperature gauge, I tried a second hand sender, the wiring, connectors on the loom etc, but in the end it was just the sender unit and from what I've been told, 99% of the time, its the sender unit that fails (probably why when I tried 3 second hand units, they all proved to be faulty) So how I got around the problem was to fit an earlier style single connector water temperature sender unit, it cost me a quid from the local scrap yard (it was from a golf) and cured the problem straight away and I've never had a single problem with the gauge since. hope this is of some use to you, Daz
Oil pressure lamp and guage wayno Electrical problems 3 10-07-10 11:18 AM
temp guage irish80sport Electrical problems 4 17-01-10 11:53 AM
Guage readings PhilGee Engine 21 18-08-09 09:07 AM
Which oil temp sender? moomin Engine 1 25-09-08 05:52 PM
Audi coupe S2 temperature guage Darron Edwards Electrical problems 4 27-08-08 07:57 PM
