Members: 19,821 | Total Threads: 40,099 | Total Posts: 471,158 Currently Active Users: 16219 (0 members and 16219 guests) Welcome to our newest member, BuddyInons |
#21 | |
fuel pressure regulator poopahoopeid..?? sounds like the systen may be receiving full pressure from the pump..not a regulated control pressure..?? expensive wee bits of metal though |
#22 |
if it was to be this would the car not even try to start as it only turns over and over and makes no attempt to fire at all ,,,would this also known as the fuel accumalator that sits beside the pump?
#23 |
#24 | |
on yours it will probably be integral to the metering head.( a little shuttle valve i think) biggyin is the man with the diagrams though..! biggyin do you have a cutaway pic or location pic for the pressure valve in the head..? |
#25 |
today i fitted a new filter and fuel pump and when checked there was massive pressure at the filter ,so i then pulled 2 injectors and fuel is getting through in a fine spray so surely the car should try to start but no it still just turns over and over ,so tommorrow all plugs get changed and injectors wiped clean as there was alot of black gritty residue on the 2 i pulled
#26 |
when I had that sort of problem years ago with a 2.8 Capri the more it turned over it would not fire for ages .the very nice man came around took out all the sparkplugs and heated them up with a lighter to remove the residue fuel and turned over the engine to remove the excess fuel in the cylinders put back the plugs and the bloody thing fired
![]() All it was i flooded it just an idea ya never know |
#27 |
micky im at the stage i will try anything now, after 4 months with the so called audi mechanic i collected it with every part i gave him stiil on the floor so im now going to have a go myself,what have i got to loose((only my mind))
#28 |
i am at a loss m8
if you were in the uk i would have helped you .its hard to do anything on the interweb just hope you can sort it . good luck and let's hope you do get to drive it on Irish soil |
#29 | |
Do you mean the pressure regulator? |
#30 |
this thing
on page 10 of this...thing...pdf..?? http://www.porsche928forums.com/down...CISRebuild.pdf it could be responsible for the 'too much fuel 'thing.? |
| need some ideas ? | Micky | General Chat | 25 | 25-01-10 11:37 AM |
| Problem, anyone any ideas? | Sie! | Suspension & Brakes | 15 | 08-07-09 11:26 PM |
| Anyone any ideas ! | Audi Dec | Suspension & Brakes | 0 | 24-06-09 11:53 PM |
| ideas please | Micky | General Chat | 14 | 08-05-09 04:39 PM |
