Classic Audi » Technical » Technical Info » compatible driveshaft bearing for 200 quattro
Old 02-03-09, 12:45 PM   #1
burny
Default compatible driveshaft bearing for 200 quattro
hello
the driveshaft bearing on my 200 quattro is "tired" after 275 000km and 21 years old.
Audi, of course, doesn't sell the single part, and they propose me the complete drive shaft for more than 1200€ !!
It seems that some drive shaft bearing from some BMW can be fit... ok, but which one ? there ar so many references ...
I would like to know if it exists a 100% plug and play bearing ?? thank you for your experience
burny is offline   Reply With Quote
Old 05-03-09, 11:11 PM   #2
quattrob81
if remember well bmw e30 1984-92 bearing will fit
quattrob81 is offline   Reply With Quote
Old 06-03-09, 08:43 AM   #3
4v6
If you can get the bearing size and if its just a case of pushing it out and a new one in, almost any bearing supplier should be able to match one up for you.
Youd need the inner bore, outer bore and width. Or just take the whole part along and see what they say.
Old 06-03-09, 08:57 AM   #4
burny
Hi
The bearing seems to be OK.
If you have a look again, you can see that the rubber is completely distended.
I have ordered this reference from Meyle : 300 261 2194/S
this fits BMW serie 3 E36.
I am waiting for the part to prepare the interface bracket
Old 06-03-09, 01:20 PM   #5
steveb
steveb's Avatar
or give pete a call at quattro corner
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
urq, driveshaft size peanut Suspension & Brakes 3 22-12-09 07:56 PM
Part number for audi 100 wheel bearing? Scarlet Technical Info 14 28-03-09 03:07 PM
driveshaft :fire: iceman98 Transmission 3 27-02-09 12:38 PM
Cam Bearing Caps Emjay Parts Wanted 24 16-02-09 07:44 PM
replacing outer driveshaft CV boots? Gaz Transmission 2 05-09-08 05:44 PM
