Classic Audi » Technical » Mech/Tech » Engine » audi 100 kv power steering
Old 14-02-09, 02:31 PM   #1
eltee
eltee's Avatar
Default audi 100 kv power steering
how do you bleed the power steering on my 100 kv 1987 PO put in atf fluid, ive drained the bottle, undone what i think is the return pipe, got about a litre of fluid out, but does it
self bleed, or is it just a case of trial and error.
much appreciated in advance
eltee
88 100 cs sport
Old 14-02-09, 04:05 PM   #2
Not sure about yours, but other cars I have done you just keep turning the steering full lock to lock a few times they Usually bleed themselves .
Old 14-02-09, 04:38 PM   #3
20vcqdriver
20vcqdriver's Avatar
Agree . Full lock to lock two or three times should do it. Did you replace filter at same time. Always worth doing if replacing the fluid.
Old 15-02-09, 12:18 AM   #4
You should turn the wheel lock to lock with the engine running, preferably with the wheels raised off the ground
1991 90 quattro
8 valve coupe power steering pump audicoupeparts Parts For Sale 0 03-09-09 04:50 PM
power steering rack audi 80, 90 ,coupe 100turbo c Parts For Sale 0 30-08-09 02:40 PM
Noisy Power steering pump? :( Gaz Engine 2 20-02-09 08:42 AM
power steering, any experts? Addicted Suspension & Brakes 1 29-01-09 07:42 PM
Audi 100 Power Steering Hose Rodders Parts Wanted 12 23-10-08 04:58 PM
