Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,131 Currently Active Users: 4836 (1 members and 4835 guests) Welcome to our newest member, BuddyInons |
#41 |
Ah, now it's understood.
Did you tried to connect that wire to both pins on sender? And did you tried to connect it to ground? ![]() |
#42 | |
Thanks. |
#43 |
Connecting it to ground will show where is the problem - if gauge remains to max, check more throughly wire between sender and gauge, if it stands @ 0, it's sender. But first try another pin.
#44 | |
Disconnected and earthed Gauge / Sender cable - Gauge stayed and didn't fly to max. This seems to confirm it is a faulty Sender. Thanks. |
#45 |
When looking for another sender, I suggest you to look for one from B3, B4, C3 or C4 A100, unless you're sure that sender from "something else" has identical function - I once tested 10 bar gauge installed in one B2, turned out that this gauge expects the same resistance range as 5 bar ones like yours or mine - which means there's also senders with 10 bar range with identical resistance... So if you would find such sender and install it in your CQ, you would complain about "low oil pressure as shown by aux gauge"
#46 | |
Mike at AUDIBITS2@aol.com is sending me one which I believe is the same, although nearly as old as mine but a fair gamble as new ones are expensive and I could easily pick up the wrong used one from elsewhere. Will post final outcome. |
