Classic Audi » Classifieds section » Parts Wanted » 1990 Audi 2309cc 20v Coupe Quattro
Old 03-01-11, 11:50 AM   #1
ksaudi
Default 1990 Audi 2309cc 20v Coupe Quattro
Oil Pressure and Oil Temperature Gauges needed - also Senders as back up.
Also Diff Lock not working but unsure of problem - interested in any likely parts.
Thanks
Keith
ksaudi is offline   Reply With Quote
Old 03-01-11, 09:35 PM   #2
Richie
Richie's Avatar
got a set of gauges in the 90 sport I am breaking if your interested?
Old 04-01-11, 09:35 AM   #3
ksaudi
Thanks Ritchie
I assume these are identical on both models?
How much do you want?
Thanks
Keith
Old 04-01-11, 10:11 AM   #4
If no joy with Ritchie, try Mike on 07809 222346, he had a red one in for breaking, don't know if he still has it, worth a call( he js in Lockerbie)
Old 04-01-11, 11:13 PM   #5
sam
for your diff lock, check the pink pipe that goes from the inlet, along the bulkhead and behind the battery, chances are its split/cracked
Old 05-01-11, 12:11 PM   #6
ksaudi
Sam
Thanks for tip. I can see a small pinkish pipe (about 4 mm dia) behind and connected to right of battery but cannot see where it goes. Is that the one? No warning lights appear when Diff Lock button pressed but could pipe still be problem?
Keith
Old 05-01-11, 12:32 PM   #7
sam
yeah thats the pipe, pull it off at the manifold and blow down it, you'll hear it if its leaking. it goes into bulkhead and end up under the back seat. if its not that then possibly the arm seized on he diff itself, but my moneys on the pipe
Old 05-01-11, 05:21 PM   #8
wildoliver
If it turns out to be the switch I have a spare or 2.
wildoliver is offline   Reply With Quote
Old 05-01-11, 05:38 PM   #9
ksaudi
Oliver
Nice to hear from you - did try to contact you.
How much would a switch be? Also do you have any Oil Pressure / Temp Gauges or Senders?
Keith
Old 05-01-11, 05:44 PM   #10
wildoliver
Hi mate, didn't get any message? Never mind probably lost in the ether!
Not much, I'll dig out what I have, How does £6 posted sound?
I do have one more set of gauges left, but really want to keep them to be honest as spares. They are just the gauges in the fascia anyway, if your fitting them to a car without gauges you need the plastic surrounds and wiring loom really too.
