Classic Audi » Classifieds section » Parts Wanted » Idle Speed Actuator
Old 07-01-10, 06:36 PM   #11
Alski501
Alski501's Avatar
Does anyone know what actual part, the number they have given to me belongs to?
035133455f, they called it an actuator but i'm guessing they wont have the knowledge you guys have.
Alski501 is offline   Reply With Quote
Old 07-01-10, 06:47 PM   #12
Martc
Black Coupe Collector
Martc's Avatar
Its the ISV - If in doubt always try a part number in google...
http://www.rmeuropean.com/Part-Numbe..._40937279.aspx
95 UrS6
87 Coupe Quattro
Old 07-01-10, 08:23 PM   #13
1985 cq kv2.2
No the opposite if anything. When cold, the car wont idle at all! As soon as you lift off the accelerator the car stalls, even when driving! Takes 6 or 7 minutes of driving before it warms up enough that it wont stall. It makes driving very awkward, will appreciate any help on this subject.
I,ll watch this thread.
I have similar problem(same engine)when cold and hot.
It stalls and then sometimes it catches(next start)and sometimes it doesn,t??
I,ve cleaned stabaliser(carb cleaner)all that did was cure idle speed.(level now)
Cleaned all breather pipes,well bunged up.That seems to has made the car more responsive.But still same problem??
When I,ve got more time I,m going to do more checks.I can put up with it for now,because it only happens every so often.
We can confere notes.
I,m going to get my multi-meter out and also test all the pressures.
I,ve read afew manuals and still none the wiser.So many Could be,s.
It will take time.
I will update you,when I do checks?
Old 07-01-10, 08:23 PM   #14
Alski501
Alski501's Avatar
Thanks Mart for that, and your other posts. So i guess i should get the isv, seems as thats the part number they have given me. So should i buy i new one, or is 2nd hand ok...and does anyone have one they want to part with?
Old 07-01-10, 08:25 PM   #15
Alski501
Alski501's Avatar
I,m going to get my multi-meter out and test all the pressures.
It will take time.
It does sound like you have your hands full as well mate...good luck with it. Mine is just from cold thankfully.
Old 07-01-10, 09:01 PM   #16
styler
styler's Avatar
have you had it on a CO meter... i just turned mine up with a long allen key...
the question i have ... my 2litre 5cyl doesnt have that valve but the 2.2 5 cyl does.... whats the difference...
CRASH VALLEY CUSTOMS
get 'er done...
Old 08-01-10, 12:50 AM   #17
it's unlikely to be the ISV if it's only showing symptoms from cold.
I'd suspect a fuel / air mixture problem. might be worth inspecting the breather and vacuum hoses on the intake and cylinder head ventilation tract
1991 90 quattro
Old 08-01-10, 01:45 AM   #18
Martc
Martc's Avatar
I am not 100% certain its the ISV causing this problem, if it was the ISV failure then the idle would be all over the place hot or cold. I would look to see if its something else first.
95 UrS6
87 Coupe Quattro
Old 10-01-10, 02:36 AM   #19
Alski501
Alski501's Avatar
Printed this thread off and showed my local garage.....they have know changed there minds and have asked me to go down the line of the warm up regulator!! I've pmd quattrokid so hopefully he will get back to me about his recon one.
Al.
Old 10-01-10, 02:44 AM   #20
Martc
Martc's Avatar
Al.
Did the warmup regulator fail the test then?
95 UrS6
87 Coupe Quattro
Central Locking Actuator Sie! Parts Wanted 4 05-10-09 02:15 PM
Idle air control valve Micky Parts For Sale 0 18-09-09 09:22 PM
Idle Stabilization Valve Ringmaster Engine 2 21-08-09 03:45 PM
90Q 10V Idle/timing issues. madwolf_uk Engine 9 14-08-09 09:18 AM
Low idle and a whine Alfashark Engine 2 29-03-09 04:10 PM
