Members: 19,823 | Total Threads: 40,093 | Total Posts: 471,115 Currently Active Users: 2807 (0 members and 2807 guests) Welcome to our newest member, BuddyInons |
#11 |
Does anyone know what actual part, the number they have given to me belongs to?
035133455f, they called it an actuator but i'm guessing they wont have the knowledge you guys have. |
#12 | |
Black Coupe Collector
http://www.rmeuropean.com/Part-Numbe..._40937279.aspx
95 UrS6 87 Coupe Quattro |
#13 | |
![]() I have similar problem(same engine)when cold and hot. ![]() It stalls and then sometimes it catches(next start)and sometimes it doesn,t?? I,ve cleaned stabaliser(carb cleaner)all that did was cure idle speed.(level now) Cleaned all breather pipes,well bunged up.That seems to has made the car more responsive.But still same problem?? When I,ve got more time I,m going to do more checks.I can put up with it for now,because it only happens every so often. We can confere notes. I,m going to get my multi-meter out and also test all the pressures. I,ve read afew manuals and still none the wiser.So many Could be,s. It will take time. I will update you,when I do checks? |
#14 | |
#15 | |
#16 |
have you had it on a CO meter... i just turned mine up with a long allen key...
the question i have ... my 2litre 5cyl doesnt have that valve but the 2.2 5 cyl does.... whats the difference...
#17 |
it's unlikely to be the ISV if it's only showing symptoms from cold.
I'd suspect a fuel / air mixture problem. might be worth inspecting the breather and vacuum hoses on the intake and cylinder head ventilation tract
#18 |
I am not 100% certain its the ISV causing this problem, if it was the ISV failure then the idle would be all over the place hot or cold. I would look to see if its something else first.
#19 |
Printed this thread off and showed my local garage.....they have know changed there minds and have asked me to go down the line of the warm up regulator!! I've pmd quattrokid so hopefully he will get back to me about his recon one.
Al. |
#20 |
Did the warmup regulator fail the test then?
| Central Locking Actuator | Sie! | Parts Wanted | 4 | 05-10-09 02:15 PM |
| Idle air control valve | Micky | Parts For Sale | 0 | 18-09-09 09:22 PM |
| Idle Stabilization Valve | Ringmaster | Engine | 2 | 21-08-09 03:45 PM |
| 90Q 10V Idle/timing issues. | madwolf_uk | Engine | 9 | 14-08-09 09:18 AM |
| Low idle and a whine | Alfashark | Engine | 2 | 29-03-09 04:10 PM |
