Classic Audi » Technical » Mech/Tech » Engine » ally fuel tank
Old 03-08-09, 11:08 AM   #1
andy
andy's Avatar
Default ally fuel tank
hi, im in the middlw of making an alloy fuel tank 600x350x300mm, can i just fit this in with the standard fuel pump etc, or as the car is turbo and injection, will I have to use 2 pumps, one from tank into a swirl pot then the original from the swirl pot to engine??
cheers, Andy
Old 03-08-09, 08:15 PM   #2
Audi Derek
“Been raced and rallied”
Audi Derek's Avatar
"will I have to use 2 pumps, one from tank into a swirl pot then the original from the swirl pot to engine"
No, gravity feed to the swirl pot (hold about 4lts) then one pump to engine. I run 2 pumps in line one as a spare.
I also run two feeds to the swirl pot one from each side of the tank so when you are cornering left or right you still are getting a continuous feed of fuel..
I wiil try and sort out a pic..
Old 03-08-09, 08:41 PM   #3
andy
andy's Avatar
ok thanks, that sounds much better, if you could send a pic that would be brilliant, so do you literally have the swirl pot fitted underneath the tank? would also be interesting to see your set up for the two pumps :-)
thanks Derek, Andy
Old 03-08-09, 08:47 PM   #4
Audi Derek
Audi Derek's Avatar
Hi Andy
No pic at the mo just looked in the album not one there, so will try and take one tomorrow but am in the middle of painting the 80gt.
Old 03-08-09, 08:50 PM   #5
andy
andy's Avatar
brilliant, thanks derek, pic would be much appreciated if you get the chance :-) also if you have a cage in yours could you get that in the pic? cheers
Old 03-08-09, 08:56 PM   #6
Audi Derek
Audi Derek's Avatar
Yep it does, I own the audi coupe quattro (clarion car stereo) rally car..
http://www.quattroforum.com/forum/yo...e-quattro.html
Old 03-08-09, 09:04 PM   #7
andy
andy's Avatar
fairplay, lovely car there!!
4x100 wheels, ally chequerplate, cd player dandan Parts For Sale 0 01-02-10 11:51 AM
Fuel tank and MOT andy Engine 12 31-10-09 07:41 PM
80/90 saloon injection fuel tank Addicted Parts Wanted 8 15-01-09 01:35 PM
Flushing out fuel tank randall977 Engine 6 20-10-07 11:00 PM
