Classic Audi » Classifieds section » Parts Wanted » 20valve head
Prev Previous Post   Next Post Next
Old 26-02-09, 02:17 PM   #17
Gaz
Gaz's Avatar
The bore is slightly larger on a 7A 82.5mm compared to 81mm for the KV but the main issue is the pistons. The 7A pistons are as shown and completely different to the KV which has a small bowl. The 7A normally runs a 10.3:1 compression ratio so you will have a KV with 20v head and low compression and possibility of valves hitting the piston. Cheaper to get a whole 7A with larger capacity which it needs to compensate for the loss of torque at low revs.
what if i wanted to put a 20valve 7A head on my 2.5?
or could i just take a complete 7 A engine and fit my crank and pistons? and have some head work done to the 7A ? would that be any easier?
90 needs new Cylinder head naffa Cars For Sale 1 19-12-09 07:43 PM
WR head quattrokid General Chat 16 20-05-09 07:53 PM
CD-less Head unit??? Gaz In-Car entertainment 13 22-04-09 11:10 AM
Wanted 20valve head. 4v6 Parts Wanted 0 17-07-08 09:26 AM
