Members: 43,066 | Total Threads: 40,086 | Total Posts: 471,053 Currently Active Users: 708 (3 members and 705 guests) Welcome to our newest member, CarolLulse |
Not holding out too much hope but anyone out there got the brackets ( with rubber inserts ) that hold on the fuel filter and fuel pump beneath the car at the R/H/S rear end please? The ones on my car disintegrated on removal of said items .
![]() name your price ! |
Make some cardboard templates, and start off your small parts fabrication in the garage.
tinsnips, dremel, etc, are going to become firm friends.
I should have done Metalwork at school instead of Art....as for firm friends, I'm already best buddies with the Swarfega tin !!!
I have the same problem and decided that (when it stops snowing) I'll try making them.
Can anyone tell me the size of the banjo fitting to said fuel pump" Also, can I use fuel hose and jubilee clips to connect the fuel pump to the fuel filter...I sort of cut the original one! ![]() |
I'm no expert but somehow doubt it as the fuel line is then under "pump pressure" and i guess all fittings from there on have to be braided hose and bolt type connectors ?
ive done a search, do you mean this.....
http://www.ebay.co.uk/itm/HOLDING-BR...item4ad6d24f8b Universal below.... http://www.ebay.co.uk/itm/58-60mm-Re...item43d33b4926 |
Thanks for those links, the rubber brackets are available from Eurocar parts I think, quite cheaply but certainly the other bracket may well be suitable. The problem one will possibly be the one that clamps the large diameter fuel filter . The whole system comprises brackets, rubber mounting galore, and just about everything has become paper thin with rust. Obviously they never planned for their cars to last 31 years.
But in that era, who did? many thanks again for those two links. |
