Classic Audi » Technical » Mech/Tech » Engine » 1982 80 CD Engine into 80 S
Old 31-12-08, 09:44 AM   #1
dav
dav's Avatar
Default 1982 80 CD Engine into 80 S
Will this engine (from my 80 CD)
Fit this car (my new whip: 80 S)
Individual Specialist Cars
Old 31-12-08, 09:50 AM   #2
First. Nice new whip fella!
Secondly, the 1.8 (8v lump I presume) is a fairly decent engine in itself so doubt you'd see any benefit if swapping over to be honest.
When you picking up the 80?
Old 31-12-08, 09:53 AM   #3
dav
dav's Avatar
Cheers, its sitting in my garage, i've not even took it on a test drive yet
Old 31-12-08, 10:42 AM   #4
Outputs pretty much spot on the same.
Guess the advantage would be the sound, smoothness etc.
WN code engine...brings back fond memories.
Old 31-12-08, 10:57 AM   #5
Now if you said about transplanting a 1.8 Turbo lump into out of of, let's say a TT for example, now that would be kinda interesting!
Old 31-12-08, 11:05 AM   #6
love the new motor Dav. Whats the story and let's have some more photo's
Old 31-12-08, 01:24 PM   #7
Ben
1.8T out of a A4 would slide in there no problem.
Old 31-12-08, 01:34 PM   #8
It should go in without too much hassle, as the same B3 arrangement was with the Coupe's, that ran 5 pots.
One thing you might find worth checking is the emissions, as the 5 pot will have had less stringent emissions in it's current body shell. The emissions are based on vehicle age, not engine age.
Old 31-12-08, 04:58 PM   #9
Ben
Dunno about "not much hastle" the four pot mounts on the subframe, you'll have to cut out and weld the five pot mounting plates onto the chassis, plus all the extra weight hanging over the front suspension will mess up the balance and brakes on the car. Seems like a lot of hastle to get something nearly like you can have already. If you're going to put the effort in, you might as well make it worthwhile....go 1.8T
Old 31-12-08, 05:17 PM   #10
steveb
steveb's Avatar
You might find the front panel is different where the rad mounts the 4 cyls have a box section to hold the rad, 5 cylinders cars don't
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
1982 Typ 43 100 CS 5E on the bay Coxy Cars For Sale 38 02-12-09 11:14 PM
audi 80 1982 Micky Parts Wanted 34 19-01-09 09:15 PM
1982 Audi 80 CD dav Parts For Sale 17 06-01-09 06:54 PM
audi 80 1982 kully Parts Wanted 3 10-11-08 09:37 PM
