Classic Audi » Technical » Mech/Tech » Electrical problems » Glowing light
Old 17-12-08, 03:06 PM   #1
Ringmaster
Ringmaster's Avatar
Question Glowing light
The oil warning light in my instrument panel on my 80 seems to glow continuously now, with the ignition on.
It is barely noticeable though.
Any ideas?
Checked oil levels etc, and all is in order.
Old 17-12-08, 04:14 PM   #2
Oil warning lights indicates no oil pressure. So although the oil levels may be ok, it may be that the oil is not flowing quickly enough around the engine.
Usually if the general rule of thumb is that if the oil light is on, it's too late and the car shouldn't be driven.
Firstly do you have an oil pressure meter? what does that indicate. If it is generating good oil pressure then it may be a sensor issue.
If you have no pressure guage I would strongly suggest you check that oil is getting around the engine and that the oil pump is working ok, oil filter isnt blocked etc
Old 17-12-08, 04:17 PM   #3
Leopold_74
Full Member
Leopold_74's Avatar
It could be just a bad Earth?
Leopold_74 is offline   Reply With Quote
Old 17-12-08, 05:19 PM   #4
PeterB
You absolute shower!
PeterB's Avatar
Or possibly a dodgy sender.
Old 17-12-08, 07:22 PM   #5
BW2309
Banned
I'd have thought most likely a dodgy earth within the dash pod. If oil pressure is genuinly low or sensor failed I think u should have a buzzer sound at above 2000rpm?
Really worth checkin oil pressure to be sure! Oil pumps on older Audi engines pretty good!
Seen a few failed dash's.
Old 19-12-08, 10:26 AM   #6
Ringmaster
Ringmaster's Avatar
I'm sure it's not oil pressure, as the light should either come on or not, not just glow feintly.
Light stops glowing with increased engine revs. Maybe its a slipping drive belt?
I adjusted belt tension, but it was difficult single handed. Maybe it's still not taught enouh.
Old 19-12-08, 10:50 AM   #7
Increasing engine revs will increase oil pressure. Light will then go out.
Again I would strongly reccomend you check the oil pressure. Sounds like the oil pump could be starting to wear out and you are getting an early warning sign. .
So at idle/low revs it may not be pumping enough oil hence the light is starting to come on. Better to replace an oil pump now than to have it go later and lose the engine
Old 20-12-08, 10:55 PM   #8
Ringmaster
Ringmaster's Avatar
Will do....................
Old 21-12-08, 07:31 AM   #9
gabriel.oconnell
gabriel.oconnell's Avatar
i had this on my quattro this years i was able to fix it with a new oil switch and cleaned up and put a new spade connecter on the new switch try connecter first
Old 25-02-09, 12:37 PM   #10
Ringmaster
Ringmaster's Avatar
Okay folks, I'm going to have to get around to tackling this fault soon.
When I do should I just replace both oil pressure switches for the sake of thoroughness?
glowing manifold? Gaz Engine 12 12-08-09 04:10 PM
90 quattro abs light 90q Suspension & Brakes 13 13-06-09 04:57 PM
oil warning light bart simpson Engine 2 09-03-09 01:22 AM
oil warning light! Jes General Chat 5 25-12-08 05:48 AM
My quad-light GT5 snorky Cars For Sale 43 09-12-08 10:03 AM
