Classic Audi » Technical » Mech/Tech » In-Car entertainment » coupe GT/new stereo
Old 07-05-10, 10:47 AM   #11
slacky
slacky's Avatar
thanks for that Marc it is all beginning to make sense with the friendly support of fellow Classic-Audi fans , it seems as though there is a feed ; the blue wire
that goes back inside the dash ,i think goes to the electric window switch and when i turn the ignition off the radio goes off as well .
Old 07-05-10, 10:54 AM   #12
Martc
Black Coupe Collector
Martc's Avatar
We can do unfriendly support as well
95 UrS6
87 Coupe Quattro
Old 10-05-10, 08:14 AM   #13
20vcqdriver
20vcqdriver's Avatar
So have you managed to get it to fit properly Chris?
Hope the quick fix works long term.... and Pete's cooking was OK bar the burnt rice?!!
Old 10-05-10, 08:56 AM   #14
slacky
slacky's Avatar
your a gentleman & a scholar ,as they say, thanks very much Dave ,, sitting nice & neat now.
just need to check the wiring on the driver side speaker , i'm sure i can do that ??
cheers again
Old 10-05-10, 08:59 AM   #15
slacky
slacky's Avatar
did you sort your wishbone bushes out Dave?
Old 10-05-10, 11:30 AM   #16
20vcqdriver
Yep! Took 4 hours yesterday. Gone is the clonking, the wayward steering and vibration at speed. Moral is stick to OEM bushes and avoid Powerflex. Just need to get tracking done now...
Old 07-10-10, 07:28 PM   #17
Dablad75
Dablad75's Avatar
Hi all, I've got an Audi GT (1984) I'm a little bit confused as I can only find 4 speaker wires, so how do I wire those into a modern stereo (the one I have has positive and negative wires for each speaker channel) ?
Dablad75 is offline   Reply With Quote
Old 07-10-10, 08:16 PM   #18
20vcqdriver
More info needed, do you have the speaker fader control below the steering wheel on left hand side. Does the car have the standard 4 speakers fitted....
Old 07-10-10, 08:26 PM   #19
Dablad75
Dablad75's Avatar
I havent seen a fader control but I'll check - but my wires do seem the same as the picture orginally posted at the begining of the thread.
I've been doing a bit of reading up and I'm wondering if the reason there are only 4 speaker wires is because they are all common earthed, if thats the case according to my new stereo install guide I'm going to have to run new wires through the car as it says not to common earth them - bugger!
Old 08-10-10, 12:48 PM   #20
Dablad75
Dablad75's Avatar
Blimey, there is a fade control! I'd never noticed!! it does have the standard four speakers, any advice gladley received -thanks.
