Classic Audi » Technical » Mech/Tech » In-Car entertainment » coupe GT/new stereo
Old 06-05-10, 01:19 PM   #1
slacky
slacky's Avatar
Default coupe GT/new stereo
right before you all go off on one , i know most people are against having new stereo's in their classic's ,so am i to a degree, i would really prefer to switch units depending on the circumstances in an ideal world...
However, i was wondering if anybody could help me to identify the wire's which are coming out of my GT dash , so i can match them up accordingly , (not very electrically minded) .
the group of wire's on the left are for the speakers,it's the one's on the right i have no idea what is what??
many thanks in advance........
Old 06-05-10, 04:04 PM   #2
4v6
From memory here so dont take it as gospel.....
Green/black and green/brown are front dash pod speakers.
Brown/blue and brown/red are rear speakers...i think?
brown wires on the white plug are ground.
Of the others youll have a 12volt permanent feed, a 12 volt accessory feed and a wire for the power aerial...all from memory so probably totally wrong...
Consult the Manuel is my best advice!
Old 06-05-10, 04:11 PM   #3
20vcqdriver
20vcqdriver's Avatar
Will dig out my drawings tonight and see if anything ties up with what you have there. Not rocket science and likely just a multimeter will sort out one from the other. Am here Saturday if no success before then...
Old 06-05-10, 06:07 PM   #4
slacky
slacky's Avatar
thanks dave,
Old 06-05-10, 06:14 PM   #5
Default Hate electrics
That looks like mine,loads of wires and no radio.(looks like someones,robbed it.)
Would the coupe wiring,be the same for mine?
Hope so,I,ve got a Blaupunkt mp3 sitting in it,s box.
Old 06-05-10, 11:34 PM   #6
Rickman
Source: Audi Official Factory Manual 4000s, 4000cs and Coupe GT (including Quattro)
Also here http://www.kvquattro.com/AudiCoupeWiring/33.tif
Rickman is offline   Reply With Quote
Old 07-05-10, 08:50 AM   #7
slacky
slacky's Avatar
thanks very much rickman, that will be very helpful
Old 07-05-10, 08:53 AM   #8
JirkaES
You should better heare the engine sound ´cause 5 cyl. sound is the best one !
JirkaES is offline   Reply With Quote
Old 07-05-10, 10:01 AM   #9
slacky
slacky's Avatar
a know you're right
Old 07-05-10, 10:25 AM   #10
Martc
Black Coupe Collector
Martc's Avatar
Its also likely you won't have an ignition sense wire the factory loom does not have it. So you will need to find a feed in that area to get one from that area of the car. So ancillariy like lecky windows or cig lighter which run on the ignition being on.
Don't take a spur off the 12v permant live to power the ignition sense for the stereo, whilst you will have a radio you can turn on with the ignition off but you will after about 3 days you will have a flat battery.....
95 UrS6
87 Coupe Quattro
