Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,132 Currently Active Users: 7806 (3 members and 7803 guests) Welcome to our newest member, BuddyInons |
Thought things were a bit funny under the left foot, but on Tuesday the accelerator pedal came adrift from it's rod. The front pedal had snapped off from it's back pedal so I now have a solid pedal attached to the end of the rod. The front pedal tilted when you depressed it. Sooo could someone look up on Ekta for me and see if they can find a part number for the pedal and it's mechanism if someone could be so kind. Be good if I can get away with just the bits on the end of the rod..............Oh it's an auto but not sure if that makes any difference.
can you put up a pic?
Do you mean the plastic tilty flappy bit has snapped off??? Can you still drive it? My plastic bit came off, and I riveted it back on with a hinge from B&Q |
Yeah that's the piece. Quite heavy duty in it's own right but snapped off it has. Still driveable as there is something of similar size under neath....it just don't tilt.
S2 did the same.... 'forceably remove' the spring that's probably sticking out of the middle of the peddle, then glue the plastic peddle cover back on... You'll never know the difference....
#5 | |
I can photo it if you would like!!! |
| hard brake pedal | damianshep | Suspension & Brakes | 7 | 29-04-09 07:08 PM |
| Audi 100 clutch pedal needed. | Lankytim | Parts Wanted | 8 | 18-04-09 06:26 PM |
| Accelerator Pump Diaphram Pierburg 2B5 | TheTwelveQuidKid | Parts Wanted | 1 | 16-04-08 12:32 PM |
