Members: 19,823 | Total Threads: 40,093 | Total Posts: 471,115 Currently Active Users: 2779 (0 members and 2779 guests) Welcome to our newest member, BuddyInons |
Cable type, for my 100 avant. Would consider whole pedal box. HELP!
1979 Allegro 1500 special (nearly back on the road after resto!) 1993 Audi Coupe 2.6 (non runner at the moment) 1996 Citroen XM 2.5 TD- Veg oil burner. 2004 Fiat Multipla 1.9 JTD ELX. ![]() "Eagles may fly high, but weasels don't get sucked into jet engines" |
Hi, Do you know if it is common to other models of that period or unique to the 100? Cheers. G.
No idea im afraid, im ringing Audi tomorrow, theyl beable to tell me if its common to other models. Hopefully theyl say they have one in stock for £10!... possibly.
If same as 80 of that period, then I removed the pedal box from my 80 Sport before I scrapped it. May also have one from a 87 coupe. Just a question of where! Sounds like it's fairly urgent; else could drop it off with space-saver on the 1st. Let us know how it goes. Cheers. G.
448721315 £44.48 +VAT, only fits audi 100/200
chacked ETKA and not fitted to any other model. did you get this sorted? eltee
88 100 cs sport |
Not sorted yet. I rang Audi and they wanted £45 odd for it with a 10 day wait for delivery. Theres a manual A100 in the local breakers ao im going to raid it when I get chance.
Give me your registeration number & your looking for a pedal box or a clutch pedal? I can ask the parts guy where I work if we have this in stock.
cheers |
Im after just the clutch pedal and my reg is C849 MTY....
UPDATE.
I found a pedal in the local breakers, fitted it today but when I tried it out I found the clutch was solid. Im guessing the clutch/clutch yoke/ release bearing has failed in a way that makes it impossible to depress the pedal but the enthusiastic "pumping" of the clutch pedal in a vain attempt to find a gear has caused the pedal to fail. Its all back together again now.... I just need to source/fit a clutch now. Im that fed up I may get someone else to fit it. I frigging hate doing clutches.
| Ebay ATE-Clutch-Master-Cylinder-To-Fit-Audi-100-200-Quattro | BIGGYIN | Parts For Sale | 0 | 26-11-09 08:01 PM |
| S6 Accelerator pedal. | Booty | Technical Info | 5 | 31-07-09 09:35 AM |
| hard brake pedal | damianshep | Suspension & Brakes | 7 | 29-04-09 07:08 PM |
| Clutch help needed ASAP | Scarlet | Transmission | 3 | 13-11-08 03:53 PM |
| Audi 100 2.8 clutch | joe90 | Transmission | 0 | 11-10-08 03:22 PM |
