-   Technical Info (http://www.classic-audi.co.uk/forum/forumdisplay.php?f=21)
-   -   S6 Accelerator pedal. (http://www.classic-audi.co.uk/forum/showthread.php?t=5905)
Booty 30-07-09 08:22 PM
Thought things were a bit funny under the left foot, but on Tuesday the accelerator pedal came adrift from it's rod. The front pedal had snapped off from it's back pedal so I now have a solid pedal attached to the end of the rod. The front pedal tilted when you depressed it. Sooo could someone look up on Ekta for me and see if they can find a part number for the pedal and it's mechanism if someone could be so kind. Be good if I can get away with just the bits on the end of the rod..............Oh it's an auto but not sure if that makes any difference.
pimpdriver 30-07-09 09:13 PM
can you put up a pic?
Do you mean the plastic tilty flappy bit has snapped off??? Can you still drive it?
My plastic bit came off, and I riveted it back on with a hinge from B&Q
Booty 30-07-09 10:50 PM
Yeah that's the piece. Quite heavy duty in it's own right but snapped off it has. Still driveable as there is something of similar size under neath....it just don't tilt.
Isimmo 30-07-09 11:31 PM
S2 did the same.... 'forceably remove' the spring that's probably sticking out of the middle of the peddle, then glue the plastic peddle cover back on... You'll never know the difference....
pimpdriver 31-07-09 08:56 AM
do it the proper way!!! a B&Q hinge (50p), 4 pop rivets and about 10 minutes of your time........
I can photo it if you would like!!!
slacky 31-07-09 09:35 AM
yes please , mine has done the same on the 90q
