Classic Audi » Technical » Mech/Tech » Suspension & Brakes » hard brake pedal
Old 22-04-09, 02:58 PM   #1
damianshep
Default hard brake pedal
hi there, just bought a 2.6e coupe and the brake pedal seems very hard.
I don't know if it's meant to be as I've been used to driving an Alfa gta, and the misses' megane, so if someone could advise.
is the pedal generally quite stiff on a 95 coupe with no ABS ( I think )?
first audi I've had since I sold my 85 sport 10 yeas ago and need some help/advice..
cheers
damianshep is offline   Reply With Quote
Old 29-04-09, 08:44 AM   #2
damianshep
ok open the bonnet and it does have abs ( should have done that first )!!
but is the pedal normally quite hard?
Old 29-04-09, 09:05 AM   #3
Addicted
No.
It may be that the ABS pump is faulty, gives the same symptoms as no servo...
1985 Type 81 2 door 2.8 V6
1983 Golf GTI track weapon
1977 Scirocco G60
1968 Sand Rail
Old 29-04-09, 11:05 AM   #4
Pete Reeve
I think you will find it has an hydraulic servo and the Accumulator has failed £200
Pete Reeve is offline   Reply With Quote
Old 29-04-09, 02:02 PM   #5
damianshep
how do i make sure that it's the accumulator thingy???
Old 29-04-09, 02:07 PM   #6
Pete Reeve
you have a hard pedal and feels like you have a block of wood stuck under it,have a look at this though
http://www.isham-research.co.uk/quat...assist_mb.html
Old 29-04-09, 07:01 PM   #7
damianshep
so is it the same system in theory as the older models?
Old 29-04-09, 07:08 PM   #8
Pete Reeve
Yes thats correct
S6 Accelerator pedal. Booty Technical Info 5 31-07-09 09:35 AM
Audi 100 clutch pedal needed. Lankytim Parts Wanted 8 18-04-09 06:26 PM
One of lifes hard decisions! audi_kid General Chat 8 28-12-08 12:33 AM
Hard to find part!!! Stu67 General Chat 1 01-09-08 05:07 PM
Well, that was hard........very hard.. Coxy General Chat 5 29-08-08 10:03 PM
