Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,148 Currently Active Users: 9207 (0 members and 9207 guests) Welcome to our newest member, BuddyInons |
hi there, just bought a 2.6e coupe and the brake pedal seems very hard.
I don't know if it's meant to be as I've been used to driving an Alfa gta, and the misses' megane, so if someone could advise. is the pedal generally quite stiff on a 95 coupe with no ABS ( I think )? first audi I've had since I sold my 85 sport 10 yeas ago and need some help/advice.. cheers |
ok open the bonnet and it does have abs ( should have done that first )!!
but is the pedal normally quite hard? |
No.
It may be that the ABS pump is faulty, gives the same symptoms as no servo...
1985 Type 81 2 door 2.8 V6 1983 Golf GTI track weapon 1977 Scirocco G60 1968 Sand Rail 2006 A4 2.0 TDI Avant = DEAD due to oil pump failure.. then alive.. then DEAD due to cam belt tensioner failure! and ALIVE again!!! |
I think you will find it has an hydraulic servo and the Accumulator has failed £200
how do i make sure that it's the accumulator thingy???
you have a hard pedal and feels like you have a block of wood stuck under it,have a look at this though
http://www.isham-research.co.uk/quat...assist_mb.html |
so is it the same system in theory as the older models?
Yes thats correct
| S6 Accelerator pedal. | Booty | Technical Info | 5 | 31-07-09 09:35 AM |
| Audi 100 clutch pedal needed. | Lankytim | Parts Wanted | 8 | 18-04-09 06:26 PM |
| One of lifes hard decisions! | audi_kid | General Chat | 8 | 28-12-08 12:33 AM |
| Hard to find part!!! | Stu67 | General Chat | 1 | 01-09-08 05:07 PM |
| Well, that was hard........very hard.. | Coxy | General Chat | 5 | 29-08-08 10:03 PM |
