Classic Audi » Technical » Mech/Tech » Transmission » clutch related rattle???
Old 20-04-09, 10:17 PM   #1
Gaz
Gaz's Avatar
Unhappy clutch related rattle???
I have an iritating rattle from under the front of the car that disapeares when i put my foot down on the clutch. ?
Is it serious? What is it?
Old 20-04-09, 10:51 PM   #2
Is there any sound?
Old 20-04-09, 11:02 PM   #3
Martc
Black Coupe Collector
Martc's Avatar
If its a knocking sound then its probably the 1st motion bearing on the gearbox....
95 UrS6
87 Coupe Quattro
Old 20-04-09, 11:09 PM   #4
Forget meaning of word "rattle"
Old 20-04-09, 11:17 PM   #5
Gaz
Gaz's Avatar
knocking? more like a loose metalic rattle.
If it is what you said, is it something to lose any sleep over? & should i be worried? and is it an engine out job?
Old 20-04-09, 11:26 PM   #6
Martc
Martc's Avatar
It will sound like a metallic rattle (knocking was the wrong word to use) Not a lot you do without a gearbox rebuild, it will probably go on for a long time with that rattle, is very common on Vauxhaull's had several from new that have done that for thousands of miles and kept going strong, although I am sure someone on here will know one way or another.
95 UrS6
87 Coupe Quattro
Old 20-04-09, 11:28 PM   #7
Martc
Martc's Avatar
Used the wrong word..... terribly sorry about that...
95 UrS6
87 Coupe Quattro
Old 21-04-09, 12:41 AM   #8
Gaz
Gaz's Avatar
dare i ask, what would have caused it?
is it an age of the car/gearbox kind of thing?
Old 21-04-09, 10:51 AM   #9
There is only two things that can make this - clutch release bearing and bearings in gearbox. Clutch release bearing makes nice rattle when clutch is disengaged, but I have heared that it may be like in your case. Gearbox main bearings would "sing" depending on engine speed
In your case I will remove gearbox [because it will be necessary anyway], then u will see how easy turns primary shaft of gearbox and u can only wish that it's release bearing and not main bearings of gearbox
Old 21-04-09, 10:47 PM   #10
Gaz
Gaz's Avatar
humm... something i'd like to add, don't know if its relevant, but might be helpful, Often when i get home from work and out of the car i can smell a burning smell. And some people have also commented on it when they've been in the car while I've been just moving off from standstill with the windows open.
I wondered if it was the clutch, but it's quite a new clutch, and it don't slip or anything.
Rattle from back of rocker? 90coupe Engine 18 09-04-11 09:35 PM
Audi related reading material rsk289 Parts For Sale 0 03-09-09 10:32 AM
HELP. engine rattle :( ferris360 Engine 5 11-05-09 07:31 PM
What Clutch to use with 7A quattropower Transmission 2 20-03-09 09:47 AM
