Members: 19,765 | Total Threads: 40,089 | Total Posts: 471,072 Currently Active Users: 1950 (1 members and 1949 guests) Welcome to our newest member, Stephencig |
I have an iritating rattle from under the front of the car that disapeares when i put my foot down on the clutch. ?
Is it serious? What is it? ![]() |
Is there any sound?
Black Coupe Collector
If its a knocking sound then its probably the 1st motion bearing on the gearbox....
95 UrS6 87 Coupe Quattro |
Forget meaning of word "rattle"
It will sound like a metallic rattle (knocking was the wrong word to use) Not a lot you do without a gearbox rebuild, it will probably go on for a long time with that rattle, is very common on Vauxhaull's had several from new that have done that for thousands of miles and kept going strong, although I am sure someone on here will know one way or another.
Used the wrong word..... terribly sorry about that...
#8 | |
is it an age of the car/gearbox kind of thing? |
There is only two things that can make this - clutch release bearing and bearings in gearbox. Clutch release bearing makes nice rattle when clutch is disengaged, but I have heared that it may be like in your case. Gearbox main bearings would "sing" depending on engine speed
![]() In your case I will remove gearbox [because it will be necessary anyway], then u will see how easy turns primary shaft of gearbox and u can only wish that it's release bearing and not main bearings of gearbox ![]() |
humm... something i'd like to add, don't know if its relevant, but might be helpful, Often when i get home from work and out of the car i can smell a burning smell.
And some people have also commented on it when they've been in the car while I've been just moving off from standstill with the windows open.I wondered if it was the clutch, but it's quite a new clutch, and it don't slip or anything. ![]() |
| Rattle from back of rocker? | 90coupe | Engine | 18 | 09-04-11 09:35 PM |
| Audi related reading material | rsk289 | Parts For Sale | 0 | 03-09-09 10:32 AM |
| HELP. engine rattle :( | ferris360 | Engine | 5 | 11-05-09 07:31 PM |
| What Clutch to use with 7A | quattropower | Transmission | 2 | 20-03-09 09:47 AM |
