Classic Audi » Classifieds section » Parts Wanted » rear end bits for the 80 Sport ?
Old 30-01-15, 04:44 PM   #1
Flying Frank
Flying Frank's Avatar
Default rear end bits for the 80 Sport ?
Not holding out too much hope but anyone out there got the brackets ( with rubber inserts ) that hold on the fuel filter and fuel pump beneath the car at the R/H/S rear end please? The ones on my car disintegrated on removal of said items .
name your price !
Old 30-01-15, 05:03 PM   #2
Hanuman
Hanuman's Avatar
Make some cardboard templates, and start off your small parts fabrication in the garage.
tinsnips, dremel, etc, are going to become firm friends.
Old 30-01-15, 07:55 PM   #3
Flying Frank
I should have done Metalwork at school instead of Art....as for firm friends, I'm already best buddies with the Swarfega tin !!!
Old 30-01-15, 08:04 PM   #4
sciteacher
I have the same problem and decided that (when it stops snowing) I'll try making them.
Can anyone tell me the size of the banjo fitting to said fuel pump" Also, can I use fuel hose and jubilee clips to connect the fuel pump to the fuel filter...I sort of cut the original one!
sciteacher is offline   Reply With Quote
Old 30-01-15, 08:10 PM   #5
Flying Frank
I'm no expert but somehow doubt it as the fuel line is then under "pump pressure" and i guess all fittings from there on have to be braided hose and bolt type connectors ?
Old 31-01-15, 01:00 AM   #6
type81
type81's Avatar
ive done a search, do you mean this.....
http://www.ebay.co.uk/itm/HOLDING-BR...item4ad6d24f8b
Universal below....
http://www.ebay.co.uk/itm/58-60mm-Re...item43d33b4926
Old 31-01-15, 11:31 AM   #7
Flying Frank
Thanks for those links, the rubber brackets are available from Eurocar parts I think, quite cheaply but certainly the other bracket may well be suitable. The problem one will possibly be the one that clamps the large diameter fuel filter . The whole system comprises brackets, rubber mounting galore, and just about everything has become paper thin with rust. Obviously they never planned for their cars to last 31 years.
But in that era, who did?
many thanks again for those two links.
