Classic Audi » Technical » Mech/Tech » Engine » Changing the engine mountings on a 200
Old 29-01-10, 06:58 PM   #1
SteveCat
SteveCat's Avatar
Default .
Hi Rob
I would only say dont jack up under a sump pan on any car mate.It will crush it.
I dont have experience with the 200 (yet),but I have either used an engine hoist (which I assume you dont have,maybe borrow one if you can),or jack up on a solid looking piece where the engine mates to the gearbox.
Steve
Mercedes E220 Sportline Coupe
Old 29-01-10, 07:52 PM   #2
missfire
missfire's Avatar
sometimes you wonder what haynes were on when the books were written.....
i'm sure mine says ''jack the sump'' too...............
would be carefull of 'lifting' too much, the engine to any extent... could stress the gearbox mounts and drive shafts/transaxles.....maybe just hold the engine where you want it..
Old 29-01-10, 08:04 PM   #3
Rob200q
Rob200q's Avatar
Thanks for the advice
I think that the jack is just put under the sump to hold the engine steady when you remove the mountings.
The only snag I can see is that you have to lift the engine slightly to get out the old mounting.
It would be beter to use a hoist methinks!
cheers guys
Rob200q is offline   Reply With Quote
Engine oil after changing Bowma Engine 15 26-01-10 04:26 PM
Fan belt changing darreno'd' General Chat 4 20-11-09 04:11 PM
changing radiator, Audi 100 2.3 pimpdriver Engine 12 08-07-09 09:01 PM
