Classic Audi » Technical » Technical Info » A4 ignition switch part number
Old 26-08-09, 10:49 AM   #1
20vcqdriver
20vcqdriver's Avatar
Default A4 ignition switch part number
Anyone out there know the correct part number for an A4 1996 (November) Ignition switch contact block. wifes car ignition switch no longer returns on its own after turning to the start position and needs manually turning back to ignition position. Thanks
Think I heard they changed during 97 year or thereabouts so need to be sure I get correct spare from GSF.
Old 26-08-09, 11:29 AM   #2
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Varies according to ETKA but i'll copy/paste the data for you to utilise.
4A0 905 849 B - F>> 8D-T-300 000 - £25.30 inc Vat (may vary slightly as my prices are updated to May...
4B0 905 849 - F 8D-T-300 001 >>8D-V-300 000 - £25.49. inc Vat
Old 26-08-09, 11:54 AM   #3
20vcqdriver
These are the 2 numbers I have, but which is the right one?
Old 26-08-09, 05:30 PM   #4
vag80
vag80's Avatar
i've got the same problem with my other halfs A4 it may not be the switch it may be the ignition barrel
which means a new barrel and key which has to be reprogramed to the car so not a cheap job
it was a recall but Audi have now stopped it, you're looking at £90+vat then someone to programe the key
200k club member
87-b3 80
83-4000 2 door
Old 26-08-09, 06:15 PM   #5
moggies
moggies's Avatar
You need to get the number off the old switch. I had the same problem last year and bought a genuine switch from TPS, trade parts specialist http://www.thetradepartsspecialists.co.uk/
moggies is offline   Reply With Quote
Old 26-08-09, 07:21 PM   #6
vag80
vag80's Avatar
is it the plastic switch that cottects to the ignition barrel that that packs up or is it the barrel it's self that goes
200k club member
87-b3 80
83-4000 2 door
Old 26-08-09, 07:27 PM   #7
moggies
moggies's Avatar
The switch is the most common thing, fits on the end of the barrel.
Steering wheel off, couling then the switch.
My wipers were first, they stopped unless the key was turned back slightly, towards off, after starting.
Old 26-08-09, 07:39 PM   #8
vag80
vag80's Avatar
i found nothing worked utill i turned the key back,i was told i need a barrel and key,if it's just the switch
that'll save alot of money
200k club member
87-b3 80
83-4000 2 door
Old 26-08-09, 08:07 PM   #9
moggies
moggies's Avatar
The spring is inside the switch, with the contacts, (sealed) so if the key will not spring back once started, its the switch. The barrel is a dumb item which just operates the lock, turning the switch, by the end of the barrel which gives the resistance.
On mine the switch had split open.
Old 31-08-09, 09:30 PM   #10
20vcqdriver
So no definite part number for a 96 A4 then. Will try and take the cowling off at the weekend...
ignition switch bart simpson Parts Wanted 0 14-07-09 02:56 PM
Ignition switch vag80 Technical Info 2 24-06-09 06:17 PM
ignition switch swappage on t85 spink Electrical problems 3 21-06-09 11:22 AM
part number for fuel pump relay Fitzy Technical Info 2 27-03-09 02:50 PM
Clutch Cable - Part Number? Sie! Technical Info 7 28-07-08 11:12 PM
