Classic Audi » Technical » Technical Info » Ignition switch
Old 24-06-09, 01:53 PM   #1
vag80
vag80's Avatar
Default Ignition switch
I know it's not a classic,but i have a problem with my A4 the ignition switch dose not return
when you start the car you have to turn the key back or the starter keeps runnig has antone had this problem or know wot parts are required to fix this fault
200k club member
87-b3 80
83-4000 2 door
Old 24-06-09, 05:32 PM   #2
steveb
steveb's Avatar
had the same fault with managements car the lock started to break up internaly i got another lock and key from a scrappy This will mean that the new key will have to be coded to the car as it won't start otherwise, I did get round this I'll pm you if you want to know what i did
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 24-06-09, 06:17 PM   #3
vag80
vag80's Avatar
so i need a new ignition lock,what are they like to change,if you could pm me how you got round the key problem many thanks
200k club member
87-b3 80
83-4000 2 door
A4 ignition switch part number 20vcqdriver Technical Info 9 31-08-09 09:30 PM
ignition switch Audi q 200 turbo bart simpson General Chat 6 20-07-09 06:12 PM
ignition switch bart simpson Parts Wanted 0 14-07-09 02:56 PM
ignition switch swappage on t85 spink Electrical problems 3 21-06-09 11:22 AM
