Classic Audi » Technical » Mech/Tech » Engine » DS Tuning
Old 25-07-09, 05:58 PM   #1
Dannny
Default DS Tuning
Can anyone suggest any way for me to get more power out of my DS engined 80 GL?
So far all I've done is replaced the middle box with a straight pipe and fitted a Weber DTML 32/34
Any suggestions/rough prices for mods would be greatly appreciated
Cheers
Dannny is offline   Reply With Quote
Old 25-07-09, 06:09 PM   #2
4v6
Free flow air filter- always go for the biggest element you can, itll have less restriction than a smaller one.
Get it tuned up, its also possible to gain a little extra here and there by optimising the cam timing.
Ensure the plugs are the right ones and correctly gapped.
Ignition system in the best possible condition and timed correctly will pay off in terms of power and economy.
After that youre into machinework and wallet pain.
Old 25-07-09, 09:14 PM   #3
Dannny
cool I've heard that early mk2 8v golf gti cams give a good gain properly set up too or would I be wasting time/money?
Old 25-07-09, 09:19 PM   #4
4v6
Depends on whether or not its a properly tested modification.
Too many are "butt" dynoed where they think theres a gain.
Far better to speak to a cam manufacturer with your intentions and let them come back with a cam spec thatll work rather than just taking a chance on something like that.
Old 25-07-09, 09:20 PM   #5
Assuming the DS engine is the 1.8 engine same as in GL Golfs (90bhp, originally Pierburg 2E2), you can fit a whole GTI Mk2 head (bigger valves apparently).
Get them for peanuts.
Or 80 Sport head.
Old 25-07-09, 09:22 PM   #6
Tony, what do you mean by "tuned up"?
Do you mean setting the timing right with a strobe light???
Or playing about with it on a rolling road until the power is maximum? (presumably rotating the distributor)
Steve
Old 25-07-09, 09:39 PM   #7
4v6
Sorry Pimp, i meant rolling road tune up.
Involves adjusting fuelling, ignition and cam timings for best power and generally ensuring everything is correctly functioning like plug leads, dizzy cap, injections carbs fuel pressure etc.
Old 26-07-09, 08:40 AM   #8
Dannny
Thanks guy's I think I'll take it up to Boggy's after payday for a rolling road session, probably best to see what I'm starting out with so I'll notice gains.
Old 26-07-09, 10:28 PM   #9
Or 80 Sport head.
Why all these problems? Just install DZ engine and that's all.
I don't know does B2's DZ have hydraulic tappets, B3's DZ uses the same head as SD and 3A, so again, nothing special.
Old 27-07-09, 09:26 AM   #10
Dannny
engine swaps not an option unfortunately, just wanted to spend a few quid to make the DS more pokey as I've got a side project with the real power
Audi 80 B2 1.8 DS tuning Szendwich Engine 56 29-06-10 04:24 PM
1.8 DZ tuning b2_sport Engine 9 16-09-09 10:31 PM
K-Jet tuning b2_sport Engine 4 18-06-09 11:22 AM
2.2 B2 Quattro Sport tuning? Kit Engine 11 04-03-09 06:01 PM
2.2 B2 Quattro Sport tuning? Kit Suspension & Brakes 3 04-03-09 12:54 AM
