Classic Audi » Technical » Mech/Tech » Suspension & Brakes » ABS Sensor Caps
Old 20-09-09, 01:16 PM   #1
Default ABS Sensor Caps
Just a quickie, 1985 WR, Ur quattro, the little ABS Sensor caps - can someone confirm the part number -
I've got 437 927 809 - Cap - qty 4 - But the diagram is pretty vague.
Many thanks
Ian
Old 20-09-09, 01:52 PM   #2
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Bob on ian
Old 20-09-09, 06:11 PM   #3
Originally Posted by Puglife View Post
Bob on ian
Thanks Jay, I need to get some ordered tomorrow then... Half way to sorting the Ur's ABS fault, after some soldering and Volt meter testing I've got the old girl working up to the point where it only fails it's rotational test sequence above 50mph and drops the ABS... My first guess is a sensor output inbalance caused by the gapping. (they've been out a couple of times over the last year)... So I'll pull the sensors and re-gap them, see where it takes me.
VBR
Ian
Old 24-09-09, 09:58 AM   #4
Well, what a result!
Our old girl's been buggering about with the ABS for about 2 years now, sometimes okay, other times failing. Cobbled through the MOT last year, but since then, it'd just persistently stopped working, and responding to me tinkering with it for that matter. Did all the voltage tests, relay tests and basically came to the conclusion the toothed cogs on the hubs were caked up... So come this years MOT, I never even tried, put the old girl in the garage and thought I'd worry about it another day.
Bit the bullet yesterday and, armed with 4 pathetic little caps, pulled all 4 ABS sensors, cleaned them up again and re-gapped them...
And.... Bugger me, the faults cured, ABS working fine now and all for the sum of £7.76.
I'd gone into 'Doom and Despondency' with it, thinking it was a £500+ fault...
So goes to show...
Thanks to Jay, and John Johnson for their guidance too...
Next step, book the MOT....
And hopefully the old girl will be polished up and down to Castle Combe on the 10th!
Where's me MAF Sensor.??? Booty General Chat 5 24-07-09 12:45 PM
Audi wheel trims hub caps Audi Derek Parts For Sale 1 18-07-09 09:14 PM
Cam Bearing Caps Emjay Parts Wanted 24 16-02-09 07:44 PM
Oil Temperature Sensor krzracingcouk Parts Wanted 7 20-11-07 03:47 PM
