Classic Audi » Technical » Mech/Tech » Electrical problems » UR driver headlight turns off with main beam!!
Old 06-05-09, 05:57 PM   #1
andy
andy's Avatar
Location: between anglesey, N.Wales and Stavanger, Norway
Default UR driver headlight turns off with main beam!!
hey guys and girls,
headlights are working fine....until i turn main beam on, it causes both driver side lights (headlight and main beam) to turn off, is also a little difficult to pull the stalk back to hold main beam on, anyone got any ideas?? its an '88 WR by the way
andy is offline   Reply With Quote
Old 06-05-09, 06:00 PM   #2
sticking relay? these are in front of the passenger side headlight, (mines yellow coloured) I recently had a similar problem with mine, turns out to be a brittle cable that was a bad connection.
swap the relays about and do you still get the same symptoms?
Old 06-05-09, 06:04 PM   #3
Probably needs a new stalk
Old 06-05-09, 06:24 PM   #4
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
You need a new stalk! This happened to me - something has broken up inside. Best get on eBay and get yourself another one!
Old 06-05-09, 06:29 PM   #5
andy
andy's Avatar
thanks for the replies, will have a fiddle with the relays and if no luck will buy a stalk, does it have to be a UR stalk or do other models use the same one, if so which models?
Cheers
Old 06-05-09, 06:37 PM   #6
Forget ebay they are or at least the mb's one is available from audi for approx £20, for that money IMHO it isn't worth buying 2nd hand
Old 06-05-09, 07:02 PM   #7
andy
andy's Avatar
Audi it is!!
cibie headlight for ur quattro or main reflector Darron Edwards Parts Wanted 4 23-08-09 05:59 PM
1982 (type 81) audi 80 rear beam/axle sprig Parts Wanted 9 01-11-08 02:04 PM
Square main beam headlight - Pre 83 quadlight randall977 Parts Wanted 2 12-12-07 10:24 PM
