Members: 19,743 | Total Threads: 40,088 | Total Posts: 471,063 Currently Active Users: 1921 (5 members and 1916 guests) Welcome to our newest member, Albertambug |
on the road again!
Hello I'm after a rear beam/axle for my 1981 audi 80 gl.
I can collect anytime & bring tools to remove it myself If needed. If anyone knows of any breaking & can point me in the right direction that would be great, please PM me with any details. Thanks. |
Mr Typ 43!
I can't help at the moment but I can tell you that any Audi 80/90 Coupe rear axle will fit. I had I put a 1991 rear axel onto my Coupe GT to upgrade it to discs (and repair the rear bushes). It was very easy to do and looked great. Most scrap yards should have a suitable Audi.
on the road again!
That sounds very promising, So just confirm for me a later model, 86 onwards (b3) will fit ok? I was thinking about that but couldn't really find any info thought it'd be good with the discs on the back. Would it then just a case of changing the handbrake cable & brake lines?
Mr Typ 43!
Anything upto 1994 I believe but please look carefully before taking anything off. As I remember I didn't have to change the handbrake cables but I did have to make up two short lengths of copper pipe to connect the existing hydraulic system to the new disc brake trailing arm. I fitted new discs and pads and it worked like a dream - took less than a day. Below is the car I upgraded using parts from a 1991 Audi 80 1.8i - it was back in 2001!
Audi-Coupe-GT.jpg |
on the road again!
Thanks for the advice randall very helpful, definately made finding a rear beam less of a headache now I know ^above^ info.......cheers me owd
If u also have idea about brake upgrade - don't forget B3's have 4x108, unlike B2's 4x100 [with some exceptions]
#7 | |
on the road again!
just another quick'un would anyone know if a 1986 Audi Coupe GT5S is 4x100 pcd? thanks again for the advice. ![]() |
Some 5 cyl typ85 was 4x108. Don't know exactly, which ones. Better upgrade to 4x108, including wheel change
86 Coupe will more than likely be 4 x 108. I think the change was in 85.
If it's a rear end brake drum type assembly then I don't think you need to change the hub assembly as the wheels bolt into the brake drum. You just need to change the drum. If you need drums I have a pair for sale on ebay 25quid 4x108 PCD |
Mr Typ 43!
Yes I concur, the rear drum / disc assembly bolts on to a standard rear beam axle.
| b3 coupe rear axle | sam | Parts For Sale | 0 | 18-11-09 10:46 PM |
| **help help** rear axle/hub | dandan | Parts Wanted | 4 | 25-10-09 10:26 PM |
| 100CS engine and rear axle | Lankytim | Parts For Sale | 0 | 16-08-09 09:39 PM |
| 1982 Audi 200 5T (Type 43) Manual | randall977 | Cars For Sale | 38 | 10-11-08 09:53 PM |
| Audi 80 (B2, type 81) 1982 rear passenger door & rear pasenger side light | sprig | Parts Wanted | 1 | 28-02-08 12:36 AM |
