Classic Audi » Technical » Mech/Tech » Engine » 200 Avant (1B) oil warning
Old 02-04-09, 05:01 PM   #1
steveb
steveb's Avatar
Default 200 Avant (1B) oil warning
'89 200 avant with an autocheck, she keeps alarming for oil level or is it pressure ? high and low alarms it even alarms when the engine is not running this is the red oil can flashing on the autocheck does anyone have any info. on how the system works ? I have changed both switches and it has made no difference The pressure gauge says all is ok
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 11-05-09, 12:02 AM   #2
Woodsman
Steve,
On my 200, 1984 KG I had a similar problem, like you I changed both switches and still no different
I tried to test the switches and came to the conclusion that the old and new 1.8 bar switches were buggered
Once again I was wrong, It turns out that the 0.5 bar (white IIRC) is a normally closed (NC) type (ie contacts are closed, then open when the switch sees pressure) and the brown 1.8 bar switch is a normally open (NO) type
The problem was that the previous owner had put the wires round the wrong way.
The garage I do some work for had same prob on a late wasserboxer campervan a couple of weeks ago, I must admit I saw the boss change both switches, then watched him scratch his head for 2 hours before I told him
Try swapping the wires, hope this helps
Peter
Woodsman is offline   Reply With Quote
Old 21-06-09, 02:23 AM   #3
5potnoodle
OCD member
5potnoodle's Avatar
Hi Steve,
Have a look on my (sadly neglected) site www.audi200.org.uk and go to the technical area. There you will find a pdf relating to fault finding of the autocheck system.
Dry solder joints on the instrument cluster printed circuit board are the usual culprits (btdt) but worth going through the correct procedure if you can to establish the course of action.
Other than the aforementioned possible causes, I'd also say that audi wiring has a tendency for the outer wire sleeve to go brittle and crack, allowing moisture in and corrosion of the copper strand inside, or even just too much verdigris on the connectors at the pressure switches where they are crimped onto the wire.
Hope that helps.
Current:
99 Subaru Forester S-Turbo Auto - interesting... but it's not a quattro
91 Reliant Scimitar SST 1400 - no.39 of 42... something for the weekend
Previous:
Two consecutive 1989 Audi 200 Quattro Turbo Avant, 1B
1990 Audi 100 SE Avant, NF
1986 Audi 100 CD Avant, KU
1987 VW Passat GL5E Estate, JS
"Honorary" triple member of the 200,000+ Club
Audi 200 in the UK (legacy website)
Classic Audi member no: 258
5potnoodle is offline   Reply With Quote
warning Micky General Chat 5 03-01-10 10:36 PM
Warning- Antifreeze stuartmmcfc General Chat 20 10-03-09 10:06 PM
oil warning light bart simpson Engine 2 09-03-09 01:22 AM
oil warning light! Jes General Chat 5 25-12-08 05:48 AM
A warning about marriage... Coxy General Chat 3 15-06-08 06:33 PM
