Classic Audi » Technical » Mech/Tech » Transmission » clutch peddle has just gon to floor
Old 21-02-09, 01:23 AM   #1
100turbo c
100turbo c's Avatar
Send a message via AIM to 100turbo c
Default clutch peddle has just gon to floor
hi just been driving out in my ur s4 and went to change gear and clutch pedle went straight to the floor , and now i can not select gears or anything , i think it must be cable snapped however the pedal just goes to the floor and locks to the flloor and does not come back up unless i pull it up, any ideas or thoughts would be great cheers
100turbo c is offline   Reply With Quote
Old 21-02-09, 07:05 AM   #2
Steve
Steve's Avatar
Check the fluid in your clutch fluid reservoir. If it's empty or it has gone down I'm guessing it will either be your slave cylinder or your master cylinder.
If it's the slave cylinder there is likely to be clutch fluid escaping from the bottom of the bell housing and dripping out from underneath.
If it's the master cylinder you should be able to feel the fluid on the foam backed mat just above the clutch pedal................lovely job !!!
Cheers,
Steve
Steve is offline   Reply With Quote
Old 21-02-09, 08:03 AM   #3
could be your pedal box come off the fire wall?
I have heard of 1 case of this happening... BIG JOB as well
sorry to hear this has happened to you
Old 21-02-09, 01:54 PM   #4
djb1607
djb1607's Avatar
Same thing happened to a friends 200. He some how can pull the pedal up with his foot and push it down when he needs to shift.
djb1607 is offline   Reply With Quote
Old 21-02-09, 07:05 PM   #5
100turbo c
100turbo c's Avatar
hi yeah found the problem its the bolt which goes to the pedal from the master cylinder has snapped , not end of the world but been on it for ages and cant see how the stud comes out of the master cylinder must do some how but am now to tired to think
Old 21-02-09, 09:39 PM   #6
Steve
Steve's Avatar
This is how it looks on a UR RR. Having done two of these so far, I don't envy you if you have to take the pedal box out as it's an awkward job.
Again on an RR the stud just fits into the master cylinder and you adjust the pedal by moving the nut on the end of the threaded bolt. Ideally you need the old one so you can put it alongside the new one for comparison.
Old 24-03-09, 11:31 AM   #7
Scarlet
Scarlet's Avatar
I have just had this fixed on my 100 q
First off it did it and if you bleed the left caliper it will come bakc up, replaced the clutch salve cylinder and it worked fione for a few months then it happened agian a few weeks back, tried the bleeding the left caliper nothing, this time it was the master cylinder got that replaced and the clutch feels brand new.
Total cost was £150 including parts and fitting for the master and if you dont take the part that some idiot mech destroyed the main dealer charged £60 fitting plus £59 for the part
t44 2.2 turbo quattro
B4 80 Avant
t44 100 2.0 saloon
Quattro Nation
Scarlet is offline   Reply With Quote
Old 24-03-09, 01:29 PM   #8
Quattro Power
Quattro Power's Avatar
Exact same thing happened to my URS4, the end which bolts to the peddle box had snapped off the master cylinder, easy I thinks, no problem to change it in-situ, when I went to do it I realised the peddle box itself was cracked and the extra strain being put on the master cylinder had caused the end to break off.................long an short of it my pal ended up being VERY VERY careful and welded in-situ because taking the peddle box out would have been a MAJOR PITA!..............its all fixed now but, but I'd check the peddle box before going any further, if the end is broken off the master cylinder its a new one I'm afraid..........£70 I think from AUDI.
Cheers!
Quattro Power is offline   Reply With Quote
Old 24-03-09, 03:56 PM   #9
gabriel.oconnell
gabriel.oconnell's Avatar
more trouble with these urs4, i hope this does not haapen too me, i had enough the s4 playing up i think the intercooler is leaking must check when i have time
Old 24-03-09, 11:43 PM   #10
should have got an auto
seriously though sorry to hear of this situ.
Gabs sort that matt carrier out will ya!!
10v turbo clutch 8690q Parts Wanted 1 27-10-09 08:07 AM
Clutch cable Audi Derek Transmission 0 26-07-09 06:50 PM
What Clutch to use with 7A quattropower Transmission 2 20-03-09 09:47 AM
floor plan irish80sport General Chat 0 04-02-09 07:07 PM
Clutch on GT5S knobstar Transmission 6 03-12-07 02:05 PM
