Members: 19,811 | Total Threads: 40,093 | Total Posts: 471,108 Currently Active Users: 11616 (3 members and 11613 guests) Welcome to our newest member, Robertreons |
Hi,
I'm dropping the kv engine from my 1986 90 quattro and replacing it with a 7a engine from a later 90. I'm sticking with the original gearbox which wont take the 7a flywheel and clutch. I've already sourced the required flywheel, from a 10v turbo ( thanks quattrokid ) now I'm after a clutch to match this. The kv clutch is far too small and the 7a clutch is only slightly to large in diameter. Sorry I don't have measurements, the clutches aren't to hand just now. According to Eurocarparts it's a 240mm clutch I need for 10v turbo wr. 230mm for kv and 240mm for 7a. I cant get the pressure plate to line up with the locators on the 10v turbo flywheel with the 240mm clutch I have. I'm needing the friction plate ? and the pressure plate ? but not the bearing as the one off the kv is used. Any help will be much appreciated. Thanks. Michael Williams. |
Whats the problem! Did this conversion myself and fitted it to the old Cq gearbox with only a change to the 7A flywheel, removing the bearing and fitting a needle bearing instead. Have all articles on this swap if you would like them. Let me have your e-mail address in PM.
| Clutch cable | Audi Derek | Transmission | 0 | 26-07-09 06:50 PM |
| What Clutch to use with 7A | quattropower | Transmission | 2 | 20-03-09 09:47 AM |
| Clutch problem | joe90 | Transmission | 5 | 08-01-09 05:53 PM |
| Audi 100 2.8 clutch | joe90 | Transmission | 0 | 11-10-08 03:22 PM |
| Clutch on GT5S | knobstar | Transmission | 6 | 03-12-07 02:05 PM |
