Classic Audi » Technical » Mech/Tech » Electrical problems » Audi 200 Quattro - Cruise Control Questions
Old 16-02-14, 10:35 PM   #1
Dave
Default Audi 200 Quattro - Cruise Control Questions
Evening all,
My car doesn't have factory fitted cruise control, looking under the bonnet I have the wiring plug for the cruise vacuum pump, would the rest of the wiring be there for cruise?
Where would the cruise control module be located on a right hand drive car?
Thanks
Dave
Dave is offline   Reply With Quote
Old 17-02-14, 05:36 PM   #2
If there is no cruise control, there shouldn't be any wiring as well - unless someone has removed stuff. Check out if there are any remains of pedal switches.
Old 17-02-14, 05:47 PM   #3
Dave
Hi,
Thanks for your reply. Yes that what I thought, there is a very factory looking correct plug with the right colour wires where the vacuum pump should go, I just can't see any other wires for the cruise control, I'm wondering if there is an internal connector under the dash where an extra bit of loom plugs....?
I have pedal switches installed but haven't found any wiring for them.....
Thanks
Dave
Old 17-02-14, 07:18 PM   #4
spink
Thanks
Dave
Im not sure about a 200 but on a c4 100/a6 it is behind the carpet just above where the passengers feet sit, rectangular silver box
Old 11-09-14, 01:07 AM   #5
5potnoodle
OCD member
5potnoodle's Avatar
Late to the party but what you require can be found on my website here
You'll need the circuit diagram for cruise control and the Fitting Locations documents.
Current:
99 Subaru Forester S-Turbo Auto - interesting... but it's not a quattro
91 Reliant Scimitar SST 1400 - no.39 of 42... something for the weekend
Previous:
Two consecutive 1989 Audi 200 Quattro Turbo Avant, 1B
1990 Audi 100 SE Avant, NF
1986 Audi 100 CD Avant, KU
1987 VW Passat GL5E Estate, JS
"Honorary" triple member of the 200,000+ Club
Audi 200 in the UK (legacy website)
Classic Audi member no: 258
5potnoodle is offline   Reply With Quote
