Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Hand brake gone!
Old 17-09-08, 12:11 PM   #1
Davey101
Exclamation Hand brake gone!
Quick question - the hand brake has just gone in my 80 GL, I assume it's the cable but haven't been able to check yet.
Where's the best place to get another one and how much work is required?
Thanks!
Davey101 is offline   Reply With Quote
Old 17-09-08, 02:52 PM   #2
couple on ebay
http://cgi.ebay.co.uk/Handbrake-Cabl...d=p3286.c0.m14
Old 18-09-08, 12:14 PM   #3
Davey101
Thanks for the quick reply!
I've just bought the one in the first link. Hopefully shouldn't be too hard to fit!
Old 18-09-08, 02:33 PM   #4
no probs, let us know how you get on
Old 18-09-08, 04:16 PM   #5
Supports or drums? If drums, does rear brakes?
Old 18-09-08, 05:04 PM   #6
Davey101
Sorry?
Old 18-09-08, 05:06 PM   #7
Why do u think cables are gone? Are u sure, rear brakes are working?
Old 18-09-08, 05:07 PM   #8
Khm, i mean - discs or drums? If drums, does rear brakes works?
Old 18-09-08, 09:57 PM   #9
Davey101
Something snapped when I put on the handbrake after arriving home from work! The handbrake had totally gone after that.
I initially thought it was the lever but after further investigation (under the leather hood) I found that the lever and ratchet were fine, they just weren't doing anything.
Khm?
It has drums at the rear. I've not driven it since it happened but the brake pedal is still working.
Old 18-09-08, 10:42 PM   #10
Nice answer to last question
Both in one time? The only thing shared there [at last on B3, on B2, I think, must be the same] is one piece of metal, which holds both cables. Get under your car and chech tension of both cables, when u will see, which one is failed. To replace cable, must remove wheel and drum, disconnect there cable...
Just bit someones hand of.. Gaz Suspension & Brakes 24 25-05-10 07:38 PM
Should I fit 2nd hand servo? spaarky Suspension & Brakes 14 21-11-09 01:08 AM
complete right hand rear brake drum and components tommyboy Parts Wanted 1 28-06-09 12:06 PM
...Cut my hand brake cable in half...Doh! randall977 Suspension & Brakes 4 14-04-08 11:29 AM
