Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Just bit someones hand of..
Old 22-01-10, 01:07 AM   #1
Gaz
Gaz's Avatar
Talking Just bit someones hand of..
saw these for sale today, and said i'd have them.
Custom made coil overs with new Bilstein inverted dampers and 2 1/4" 450lb 8" Faulkner springs.
pick them up on Tuesday with any luck.
Old 22-01-10, 11:52 AM   #2
Martc
Black Coupe Collector
Martc's Avatar
Nice Purchase
Quick question.... have you got ABS on your car? If so are these ABS struts?
Non ABS struts don't have the place to fit the ABS sensor.
95 UrS6
87 Coupe Quattro
Old 22-01-10, 12:34 PM   #3
peanut
Very nice, are you getting him to build the rears for you too?
Old 22-01-10, 08:57 PM   #4
Gaz
Gaz's Avatar
Unhappy
Nice Purchase
erm...
Are these not ABS struts then? Hadn't even given that a throught. Can you tell from the pictures???
if not, can they be modified to fit the ABS sensor? or something removed from my struts and fabricated on to these?
permission to say oh cock.
Old 22-01-10, 09:23 PM   #5
missfire
making wooden things
missfire's Avatar
are these abs bits....????????
Old 22-01-10, 09:39 PM   #6
they look like ABS units, although the one on the right looks to have part of the bracket broken (it may be a bad photo)
1991 90 quattro
Old 22-01-10, 10:06 PM   #7
Gaz
Gaz's Avatar
So if they are the ABS bits, could the bit on the one on the right be repaired?
Old 22-01-10, 11:55 PM   #8
Martc
Martc's Avatar
Originally Posted by Gaz View Post
erm...
I can't tell from the pictures without looking at both my cars. Luckily I have one of each type. I'll take a look tomorrow
I just remembered on of your other posts about ABS sensors and thought I would ask. I doubt it would be easy to convert if they are non ABS hubs as the alignment of the ABS sensors is critical to its operation.
If these struts are ok, make sure you remember to purchase new ABS caps for the sensors, these set the correct gap between the sensor and the Hub, otherwise it will be the orange lamp of doom!!!!
95 UrS6
87 Coupe Quattro
Old 23-01-10, 12:54 AM   #9
styler
styler's Avatar
nice one..... gonna build a set for my 90.... ill be lookin at these pics to keep me right now...
CRASH VALLEY CUSTOMS
get 'er done...
Old 23-01-10, 03:24 PM   #10
Gaz
Gaz's Avatar
he said they are indeed ABS versions. plus he will TIG weld the tab back on to the other leg.
Tags
coilover
Should I fit 2nd hand servo? spaarky Suspension & Brakes 14 21-11-09 01:08 AM
Someones annoyed at Tesco! Lankytim General Chat 1 08-07-09 07:39 PM
Hand brake gone! Davey101 Suspension & Brakes 9 18-09-08 10:42 PM
