Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,120 Currently Active Users: 8773 (0 members and 8773 guests) Welcome to our newest member, BuddyInons |
#61 |
Location: between anglesey, N.Wales and Stavanger, Norway
i pulled some kind of sensor out of the top of the inlet manifold, a round one held in with 2 allen bolts. it's a green dash actulaay, is there any kind of fault codes on this or like old astras when you connect some rubbish with a paper clip then read the flashes on a light? seemed like it was only happening in 2nd when i last tried it, strange i thought!
#62 |
sorted all thw wires behind the glove, thought it was fine, but today...its back :-(.
drove fine but stuttered a little at 4000 then climbed to around 5000 and stuttered again ...any ideas? cheers, Andy |
#63 |
Mr Sixty Thousand!!
This 4000 rpm bit still leans toward the air inlet temp sender, but i'd be interested to know what the boost level is when it happens. If the ecu see's too much it will cut the fuel pump, but, tbh when this happens you think the engine has fallen out, not just a misfire !
http://www.oesems.co.uk/ |
#64 | |
was thinking that maybe the air temp sender could be buggered, or is this unlikely? cheers, Andy |
#65 |
have you changed your fuel filter? Read my thread on my antics over the weekend!!!
#66 |
what colour were the wires behind the glovebox? mine did a similar thing where the fuel pressure regulator on the block was fecked. this over fuelled the engine and made it misfire. try that.
#67 | |
I'll try that one, the wires were all kinds, think theres a pic further up. cheers |
#68 |
#69 |
#70 |
think maybe i solved it but havent tested it yet as theres no wheels on her 2day but.... as ashamed as i am to say it.....i think it was just a buggered battery connection....oops. will update later on once its been for a run though
| 88 wr misfire :-(!! | andy | Engine | 2 | 30-11-09 06:28 PM |
| EKKKKKKKKKKKK Nasty, nasty 80 | amanda | General Chat | 11 | 26-04-09 07:56 AM |
| Nasty...one lucky sod. | Booty | General Chat | 15 | 02-10-08 09:13 PM |
| Anyone got or had a misfire on K jet engine? | Octanejunkie | Engine | 21 | 15-05-08 10:25 PM |
