Classic Audi » Technical » Mech/Tech » Suspension & Brakes » G60 twin pot calipers on B2 80
Old 15-04-14, 11:48 AM   #21
Could, you, please, learn to post images? I at first, when seeing first post thought that you're just writing something, only selecting "quote" turned up that you've posted some images, unfortunately, you want to post webpages, that contain images, not images themselves. Sometimes I feel that it's the privilege to be able to click "copy image adress"
Wind yer neck in wud ya
Old 15-04-14, 03:54 PM   #22
b2_sport
b2_sport's Avatar
Originally Posted by mikes2 View Post
Not wanting to throw a spanner in the works but there are two different discs available for B3 cars
276x25 51mm height - these fit 90 20v
276x25 56mm height - these fit Coupe 20v
Those look like Coupe discs so you'll need Coupe hubs
Are the coupe hubs a bolt on job for the B2?
Old 15-04-14, 04:57 PM   #23
Think that's a moot point since the caliper carriers won't fit on the B2 hubs anyway.
If you do go with brackets, does this retain your offset and keep the carrier in the correct place ?
1991 90 quattro
Last edited by mikes2; 15-04-14 at 04:59 PM. Reason: more typing. hit submit in error
Old 15-04-14, 05:52 PM   #24
lefthooker
Old 15-04-14, 06:48 PM   #25
Val
Val's Avatar
No, forget about this topic before swapping to 2-piece struts.
Val is offline   Reply With Quote
Old 15-04-14, 07:14 PM   #26
spink
Another option is g60 calipers(s2/20v/2.8) with one piece early b3 struts and using corrado or golf 280x22 discs with pcd redrilled to 108,also centre hole opened up from 65 to 68.
This is what a mate of mine used years ago on his cq
Old 15-04-14, 08:19 PM   #27
That's,what I'll be doing.
KARL.
Old 15-04-14, 08:23 PM   #28
b2_sport
b2_sport's Avatar
I have ordered a set of brackets from flea bay and am going to try the Audi discs that I have got as pictured. If not I may go down the focus 4x108 discs route.
Old 15-04-14, 08:23 PM   #29
Val
Val's Avatar
Yeah, doing more work to get the same result
