Classic Audi » Community » General Chat » More power from a 1.8 k-jet engine in a 80 sport
Old 26-01-12, 07:13 PM   #21
murran
murran's Avatar
wish i had some more pics of the work i did on that golf. sadly this all happened pre-internet access/forum involvement, so never really bothered taking pics.
was one of the first things i ever bought off ebay for £104. was a total shed. from a bent driveshaft to a new clutch, new back panel welded in, heater matrix, fitted rainbow interior, rebuilt the sunroof with a new rear drip tray and seals....... jamex springs and shocker kit. green stuff pads.
sorry im getting off topic!!
yeah the kv throttle body is much bigger.
i couldnt really tell you want difference it made on its own as i fitted it at the same time as the cam! doh. was much more grunty at the top end.
also my mate had an mk5 escort gti 130. was never able to keep up with him on the road..... after the cam and stuff i was able to keep right under his bumper!
from memory i had to mix/modify/swap some little brackets for the throttle cable. i swapped the tps too, but i cant remember if this was cus it was different of cus the kv one came without a tps.
removed the inlet to bore it out, took about half an hour ish to die grind it out.
if you put a kv body next to a gti one the difference is huge.
murran is offline   Reply With Quote
Old 26-01-12, 08:18 PM   #22
B2AUDI80
B2 Brigade
B2AUDI80's Avatar
yep the kv throttle body is larger as murran says, ive a kv one there for my sport , whenever i get round to fitting it
it was actually a popular mod by mk1 golf owners years ago
www.northernretros.co.uk
1984 80 Sport
1970 hb viva
1983 Honda Odyssey 250
1981 Suzuki 450 GS
1980 t25 danbury
Old 29-01-12, 02:19 AM   #23
Rickman
My friend and I did the 2.2 kv throttle body and warm up valve swap on his 1.8 8v mk1 Golf. Advanced the timing to 17-18 degrees (a large advance from 12), used a solid injection air pipe to stop collapse under heavy throttle and finally drilled many 3" holes through the bottom of a rs turbo air box. Standard 1.8 engine on a 1.6 gti box.
Supposed to give a genuine 8-10 hp, I can tell you it makes all the difference as the first butterfly @ 2.2 is the size of the second @ 1.8, but the the second 2.2 makes both 1.8 butterfly's look small.
The milestone test was a short hill on the way to his house. In standard trim with 1.8 parts the car peaks the hill flat in 2nd. After the part swaps and the advance, the car peaks the hill somewhere in 3rd.
End result, instant hard power in any gear up and beyond the profile of the cam (8000rpm).
Rickman is offline   Reply With Quote
Old 29-01-12, 10:36 AM   #24
K Simmonds
K Simmonds's Avatar
The best route to more power with Four pot K-Jet motors, 16V or 8V is more displacement using a SHORT STROKE bottom end, 6A/9A for 16V's or 3A/AAD for 8V's, for example, combine these with head work for excellent results.
These are just the common ones, many others are out there, though not all in the UK.
There are quite a few other VAG models for the late 80's and early 90's with variants of the 2.0 short stroke bottom end. These are basic but useful guide's to what you might find hiding under the bonnet of various Audi's or VW's either in scrappers or just going cheap. Pity the these list's don't tell you how many cylinders or valves the engines have as there are quite a few five pot 2.0 engine to confuse matters. But still, with a bit of cross referencing and research you will find easy answers.
http://www.autoshoppingcenter.com/Vo...ginescode.html
And that's just the Audi units
Here are the VW ones,-
One of these bottom ends combined with some basic head work/multi angle valve seat cutting plus good assembly practice such as matching up manifolds ect is far and away the most effective solution.
Forget the latter long stroke blocks, they don't like to rev unless heavily modded and don't really fit properly in a car that had a 1.8 short stroke bottom end as standard.
K-jet can be made very reliable at the higher flow levels involved, the warm regulators can be tweaked as can the metering heads. There is also much choice when it comes to injectors. Going Common rail with EFI is unarguably better, especially when it come to economy but is far from being essential for good results.
Carb's and individual Throttle bodies are a waste of time unless you REALLY know what you are doing and have cams custom profiled to suit.
Old 29-01-12, 08:55 PM   #25
b2_sport
b2_sport's Avatar
kents cams do one for the DZ, 10hp gain £194.00 +vat as of 25/01/2011.
Wonder if they would do anything for a group buy, who else is interested?
We could even have a dyno/tune up meet in the near future, i know theres a few 80 sport owners here...
Old 29-01-12, 09:10 PM   #26
SteveT63
SteveT63's Avatar
I'll have a word with Ben at Shark. He might like the idea of a Retro Rolling Road Day. Bapro set up at his place and plenty of space for the BBQ as well.
www.sharkperformance.co.uk/
T85 1985 90quattro I5 20vT
T81 1983 80 Sport Red
T81 1983 80 Sport Silver
