More power from a 1.8 k-jet engine in a 80 sport
I'm looking for some more power out of my 80 but don't want to change the engine thought about turboing or supercharging But it's looking like nether is possible. just thought if any one had any tips or links for more power out of these engines which sum one must then could u give me a heads up cheers
How about ditching the fuel injection system and fitting some carburettors?
I think you will need a 1.8 gl head though for the carbs |
How deep are your pockets?
Big valve head, polished, ported, highlift cam, throttles bodies or twin carbs, stainless exhaust manifold and system. The works 80 Touring Wagen was getting on for 170bhp from a 1600cc engine!! I think TSR still do some nice trick bits for the DZ engine. :tup: |
If one wanted to replace the stock exhaust with something a bit sexier, nothing mad just a nicer looking tailpipe and improved sound... where would one start looking?!
Jetex still do exhausts ( or did last year) for these cars.
Any Golf GTi engine mod is suitable; I'd start at TSR or C&R Enterprises . 2.1 litres is the biggest you can get to - and you had better have a very deep pocket ( replacement block/crank etc but 1.9 is sooo much cheaper... |
1.8t 20v conversion will probably set you back the same amount as tuning the DZ
Nice sound, not too 'bad boy' and full stainless so no rust! |
Have you actually driven your 80 sport? There quick as there are as standard!
RMS In prestwick manufacture a stainless system with any end you want and any bore. OR there Longlife exhausts also in stainless down in "Engalund" just Google 'em!
You can carb the DZ, you just need to block off the injector holes, this way you retain the bigger valves and higher lift cam of the sport head.
Either machine up some bits to slot in, or use 1p pennies! Lol. Seen that on vw forums tho I doubt they are good for flow it might be my quick fix if I don't have time to make up the plugs! Lol. |
| All times are GMT. The time now is 06:40 PM. |
