Classic Audi » Classifieds section » Parts Wanted » 100 Turbo Fuel Metering Head Engine code MC
Prev Previous Post   Next Post Next
Old 10-05-08, 12:52 PM   #6
Rodders
Car starts and runs fine cold but as soon as it warms up I cant get it to idle reliably below 1200 rpm, it hunts about and the CO reading is really low. Doesn't respond to adjustments to the mixture screw and the CO readings fluctuate anywhere between 0 and 1% but it always settles to a really lean mixture. When really hot if it stalls, it will not start again until it has cooled down (no fuel pressure?),then it will start and run fine until it warms up(not great when you fill up for petrol!) I thought it was an air leak but cant find one anywhere and I have swapped the warm up regulator with a spare which made no difference. Idle stabiliser valve is fine and has also been swapped with a spare to make sure. I am running out of ideas other than the metering head. It does have a cat so wondered if it might be something to do with the oxygen sensor or something.
I spoke to KMI as pimpdriver suggested, really helpful guy there but dont want to send it to them until I'm sure it is the metering head. Flow to head is fine but haven't been able to check the injector side. Drives fine when warm, its just the idling.
Rodders is offline   Reply With Quote
Fuel metering head/distributor needed for 2144 80 quattro. naptik Parts Wanted 4 04-02-10 08:45 PM
turbo 10valve inlet manifold + metal piece from metering head Gaz Parts Wanted 6 29-11-09 04:27 PM
type 43 metering head for fuel injection unit jack1 Parts Wanted 10 15-11-09 09:13 AM
80 Sport Fuel Metering Head Needed, Same as Mk1 GTI??? rado-steve Parts Wanted 12 02-03-09 01:18 AM
Jetronic Fuel Metering Head / Air Flow Meter randall977 Parts Wanted 5 17-12-07 04:26 PM
