Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Why are VAG rear calipers crap???
Old 27-11-09, 11:22 AM   #11
It looks like Paul in Luxembourg has replacement calipers.... for several different cars......
http://homepage.internet.lu/customau...100_200_v8.htm
Old 27-11-09, 11:28 AM   #12
paulfern
Default New rear brake calipers...?? (improved design)
Maybe this can help ...something new I did up a few months ago..(ok I actually took over 2 years of research and development to make them!)
This was a completely new design of the older VAG calipers I did....based on the current GOLF or AUDI A3, A4 , A6 ...
This is the Quattro version (with 38 piston)
Here one of them mounted on an Audi 100 quattro.
These things have dual o-rings for better water intrusion....I designed them to last A LONG TIME!
And NO they do not cost an arm or leg...I offer these at less then 1/4 price of VAG...plus I throw in new brackets and pads.
Where to find our more about these things?-->
http://homepage.internet.lu/customautocraft/typeB2_80_90_4000.htm#BRAKES
paulfern is offline   Reply With Quote
Old 28-01-11, 08:02 PM   #13
Found this page which looks good:
http://forums.audiworld.com/showthread.php?t=2770104
Old 28-01-11, 08:17 PM   #14
Hi
i had a new rear caliper in January 2008 and it has already siezed. I had both rear calipers deseized in April 2009 and the handbrake has approx 4" of free travel before it moves the calipers (ie slack cable) . Both cables are fine.
Speaking to my mechanic he said late 80s early 90s VAG rear calipers always seize (the reason why people put golf mk4 calipers on golf mk2).
Can any later audi calipers be fitted to the rear of my 1990 audi 100 quattro???
That's because you 'Nancy-about' on those Gay little winter tyres that are only speed rated for a milkfloat.
Get the old girl up to some serious speed and grind the buggers down, get some (short term) heat transference, get the things working occasionally rather than this 'oooh, it's a bit fanny-about-braking-again-time'...
Old 28-01-11, 08:32 PM   #15
Phil Payne
Banned
Possible. Also possible they weren't correctly fitted:
http://www.isham-research.co.uk/quattro/caliper.html
Old 28-01-11, 08:33 PM   #16
james brazier
One of the problems associated with calipers not working right is the spring on the outside, it's too soft, Ford Sierra or Scorpio springs were stronger, yiou used to be able to buy them as a kit, sadly went nla from ford a long time ago
james brazier is offline   Reply With Quote
Old 28-01-11, 08:43 PM   #17
styler
styler's Avatar
mmmm calipers...... nice work..
CRASH VALLEY CUSTOMS
get 'er done...
Old 28-01-11, 08:51 PM   #18
And only cost about £106 each.
Old 28-01-11, 08:55 PM   #19
missfire
missfire's Avatar
hmmm! those handbrake quadrant seals look like a possible for my 100t, it failed the last m.o.t. on a siezed rear caliper....(before my time mind! i'd have sorted it before the m.o.t...)
will have a look!
Old 28-01-11, 08:58 PM   #20
styler
styler's Avatar
£212 whats that in yo yos.... about €300 are they available for a coupe i wonder... be needin a set for my 90 whenever that gets done..
get 'er done...
Audi 200Q 20v or Avant Rear Calipers... Dave Parts Wanted 0 05-12-09 08:28 PM
Crap youtube Vid - T5 on the A27 TheTwelveQuidKid General Chat 5 08-08-09 03:17 PM
crap Monday joke! Coxy General Chat 1 10-03-09 08:25 PM
UR S4 Rear Calipers mortcars Parts Wanted 3 23-12-08 06:37 PM
rear calipers seized pimpdriver Suspension & Brakes 0 16-12-07 07:58 AM
