Members: 19,823 | Total Threads: 40,093 | Total Posts: 471,115 Currently Active Users: 2773 (0 members and 2773 guests) Welcome to our newest member, BuddyInons |
Classic Audi Pervert!
Hello all
You may not have seen much activity from me on here recently, I've been busy fixing up the 200 turbo and getting your Christmas pressies sorted out - the 2010 calendar! ![]() Anyway...I need your help! The 200 turbo is running too hot when driving at slow speeds and when stationary. Since I've bought it and the problem becoming apparent, I thought it would be a good idea to flush the radiator completely and put new antifreeze in (stuff that was in there was bright green! ) and have fitted a new fan switch (thought it may be faulty and not working on the first speed).Nothing has changed...it's still the same. The fan cuts in at three quarters by which point it's pretty hot and struggles to get the temperature down (just stays in the same position). Once the car is turned off, it'll sit there for 10-15 minutes with the fan on until it's cool again. It can't be the thermostat because it warms up normally and sit's between a quarter and a half when driving normally.The good news is the fact that it's never actually overheated, just runs hot! Has anyone got any ideas? Starting to pull my hair out over this one! Thanks |
What temps the thermostat supposed to open at and does yours do it?
have a look at this excellent website:
http://www.sjmautotechnik.com/troubl...lec.html#after http://www.sjmautotechnik.com/troubl...ing.html#after Steve |
Thanks for your replies!
Wish me luck! ![]() |
Are u sure your A200 really have cooling fan slow speed function? How much pins have that fan switch u installed - two or three? And how much wires have connector?
From what material is your radiator made? |
big gimping
hahaha had a similar problem once in a polo coupeS just whack the heater on full blast and get ya windows down, it sucks all the hot air off the engine (it does work!) that was until i went and bought a new fan
I was just going to ask you if you'd sorted it, obviously not.
If the fan is only cutting in at full speed, and not at mid speed first. I'd check the fan resistor, mounted infront of and below the rad, that link that pimpdriver put up tells you how to check this. Glad I read that, as I was going to fit a lower temp fan switch (golf mk3) but if mpg suffers I won't be bothering. |
If it's not overheating, don't worry about it!
you might have a partialy blocked rad
could it be air in the rad??
| Running probs | vag80 | Engine | 9 | 30-07-09 06:33 AM |
| running problems | Amar | Engine | 25 | 19-05-09 08:33 PM |
| Anyone Running LPG? | Jabber | General Chat | 0 | 13-01-09 08:34 PM |
| anyone running after market ecu on 10v? | sam | Engine | 5 | 03-01-09 10:33 PM |
