Classic Audi » Technical » Mech/Tech » Engine » Running probs
Old 29-07-09, 07:08 PM   #1
vag80
vag80's Avatar
Default Running probs
i had a phone call tonight from a mate who is having problems with his B4 80 it is a 2.0
ABK engine it runs rough at idle until you unplug the maf sensor then runs ok so he's fitted a new one it's no better he's also said that he can't set up the timing as the mark are jumping all over the place,i've told him a few things to look at has anyone got any ideas as to wot the problem could be any info would be welcomed (the head has just been rebuilt)
200k club member
87-b3 80
83-4000 2 door
Old 29-07-09, 07:11 PM   #2
Hmmmmm are all breather hoses connected properly?
Old 29-07-09, 07:12 PM   #3
sam
timing belt a tooth out?
Old 29-07-09, 07:16 PM   #4
vag80
vag80's Avatar
i've be told all the marks line up as they should,it runs ok when the maf is disconected but the timing marks on the flywheel jump all over the place
200k club member
87-b3 80
83-4000 2 door
Old 29-07-09, 07:18 PM   #5
vag80
vag80's Avatar
from wot i've been told they are all fitted correctly,i can't go and look at the car as he lives near Bromsgrove
200k club member
87-b3 80
83-4000 2 door
Old 29-07-09, 07:27 PM   #6
sam
does the mark steady itself out when its rev'd? as i think thats normal
Old 29-07-09, 07:36 PM   #7
vag80
vag80's Avatar
that i'm not 100% sure, but it's not right as you should be able to set the timing with it idling with a strobe light which he can't as the marks are jumping alover the place
200k club member
87-b3 80
83-4000 2 door
Old 29-07-09, 08:14 PM   #8
kully
kully's Avatar
There is a relay under the drivers side of the lower section of the dash, you have to remove the tray, there is a relay which controlls the ecu has a no 6 on it I think. This relay costs £10 from audi, We changed the cat, lamba sensor, distibuter, leads, all sensors, all genuine parts and the car still played up untill this cheap relay was changed.
Old 29-07-09, 08:23 PM   #9
vag80
vag80's Avatar
cheers mate i will tell him
200k club member
87-b3 80
83-4000 2 door
Old 30-07-09, 06:33 AM   #10
rsk289
Try putting a jump lead between the body of the lambda probe and a good earth and see if there is any difference in the idle. Sensibly positioned you can make/break the connection whilst the engine is running and compare the idle. My father had similar symptoms on his coupe and this improved it. Basically lambda probe not earthing due to corrosion.
rsk289 is offline   Reply With Quote
Timing belt probs. PhilGee Engine 8 24-05-10 06:47 PM
Anyone Running LPG? Jabber General Chat 0 13-01-09 08:34 PM
break probs kerker21 General Chat 3 12-11-08 10:57 PM
Not a quattro .... but probs a lot rarer ;) Tom C Spotted! 3 11-02-08 11:39 AM
