Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Audi 80 B3 brake upgrade problem!
Old 11-09-09, 09:38 AM   #11
Falcao
Hi Everyone! Only to say the brakes are working!
The main diference is the Hub! The tdi Hub is bigger then the one i have! It makes the disc fit perfectly!
Soon i post pics! Its really good upgrade for an B3 Turbo diesel ( 1.9 engine runing)
I m really thankfull to the ones who help me with this "swap".
Thanks!
next step is swap the engine..
Cheers
Falcao is offline   Reply With Quote
Old 12-09-09, 07:13 PM   #12
Falcao
Hi all!
Here we have some brake upgrade photos!
Shot at 2009-09-12
cheers|
Old 18-09-09, 05:32 PM   #13
Tone
Tone's Avatar
Send a message via MSN to Tone
I was going to say it's the hubs lol.
Had a later B4 set-up on one corner of mine and the correct B3 type on the other!!!!
So upgraded to a Coupe spec ATE set-up (more because i had to rather than wanting to!)
B4 and Coupe hubs are the same, both have a wider track than the B3, about 40mm wider in total.
Should sharpen up the handling a tad too
1993 'B3' Super Wagon
Tone is offline   Reply With Quote
Advice On Brake Upgrade For UR Steve Suspension & Brakes 1 02-01-10 10:09 PM
Brake upgrade for 84' type81, itsa-dubthing Suspension & Brakes 5 31-12-09 10:18 PM
Brake problem - 200 turbo 86audicoupe Suspension & Brakes 17 09-10-09 11:29 AM
CQ Brake upgrade? Gaz Suspension & Brakes 5 27-09-09 04:34 PM
audi quattro brake problem newt Suspension & Brakes 11 04-06-09 09:48 AM
