Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Audi 80 B3 brake upgrade problem!
Old 14-08-09, 10:22 AM   #1
Falcao
Exclamation Audi 80 B3 brake upgrade problem!
Hi! Yesterday i tried the brake upgrade but no sucess!
The Audi 80 is B3 from 1989 and uses single disc 256mm.
Brakes upgrade:
Corrado G60/ S2 calipers + audi coupe 2.2 20v quattro discs vented (276mm 4 studs).
The problem is the disc crash into the "arm" (spindle carrier)
Here you have some pics of the calipers and the arm
I think i need to change the "arm"..
Waiting for help!
Kind regards,
Mário
Falcao is offline   Reply With Quote
Old 14-08-09, 05:22 PM   #2
vag80
vag80's Avatar
were dose the disc touch the capliper carrier
200k club member
87-b3 80
83-4000 2 door
Old 14-08-09, 05:27 PM   #3
Falcao
I cant fit the disc in the center of the hub, because it touch in the spindle carrier
Old 14-08-09, 05:36 PM   #4
vag80
vag80's Avatar
wot year coupe dics are you using as yours is a latter b3 80
200k club member
87-b3 80
83-4000 2 door
Old 14-08-09, 05:52 PM   #5
Falcao
I don t know.. I m not sure even if it is from a Coupe, but i have here the box and info disc. I think is from a coupe 2.3 20v between 1990 and 1991.
When i bought i saw the list and searched by diameter and holes. And seams to be all the same. All 276mm have the same dimentions..
Delphi ref. BG2748
Overall Height = 56.2mmVented Mountings 4
Discs diameter 276mm
Discs thickness 24.9mm
Overall height 56.2mm
Centre diameter 68mm
Minimum thickness 23mm
Old 14-08-09, 05:57 PM   #6
vag80
vag80's Avatar
you may need the front discs from a 90 b3 shape or the whole front brake set up which has twin piston
capilers
200k club member
87-b3 80
83-4000 2 door
Old 14-08-09, 07:46 PM   #7
john881000
john881000's Avatar
Default Brakes
hi
you can try the discs from B4 Audi 80 V6,you got the later type strut /bearing housing,if you had the old type set up as on my Audi 80s you cant use them,but as you got the later set upoof bearing housing you might get to use them.....the the calipers
Hope this idea helps
cheers
john
john881000 is offline   Reply With Quote
Old 15-08-09, 03:29 PM   #8
Falcao
Hi!
Anyone knows if the spindle carrier of the B4 tdi is the same as mine (B3)?
If it was a B4 these brake upgrade would feet?
I use these link to see the disc dimensions..and with the V6 disc i will have the same problem.. the overall is 56.2mm
http://www.brakepartssuperstore.org....d116_Audi.html
Old 15-08-09, 04:30 PM   #9
sam
hi falcao, the calipers and carriers are g60 twin pots from a 1991 audi 90 quattro 20v, hope this helps with finding correct discs
Old 15-08-09, 04:58 PM   #10
Falcao
Hi Sam! The problem is not the calipers, neither the discs.. The problem is the spindle carrier. The B4 have diferent disc offset. I think if i have a B4 it would fit perfect.
The disc i have is the same as audi 90 quattro 20v. (276mm vented )
Anyone can show me the spindle carriers of a B4 TDI (with vented discs) or Coupé 2.3E 20v, or Audi 90 quattro 20v.
I need to know the diferences between the spindle carriers of B4 and mine B3.
Any info wellcome!
Advice On Brake Upgrade For UR Steve Suspension & Brakes 1 02-01-10 10:09 PM
Brake upgrade for 84' type81, itsa-dubthing Suspension & Brakes 5 31-12-09 10:18 PM
Brake problem - 200 turbo 86audicoupe Suspension & Brakes 17 09-10-09 11:29 AM
CQ Brake upgrade? Gaz Suspension & Brakes 5 27-09-09 04:34 PM
audi quattro brake problem newt Suspension & Brakes 11 04-06-09 09:48 AM
