Members: 19,772 | Total Threads: 40,089 | Total Posts: 471,076 Currently Active Users: 1741 (1 members and 1740 guests) Welcome to our newest member, Esmeraldosvhc |
my 90 with a kv hesitates under hard acceleration. it feels just like the rev limiter kicking in only at about 3500-4000rpm. in fact im 90% sure its the rev limiter. the cars had new plugs, leads and filters. dizzy caps recent too. rotar arm next to change but i dont think this will cure it
anyone any ideas?? |
#2 | |
On the KV type arm, the spring can become weak and set a low rpm limit... our RallyRep when we got it was at 5200rpm... So I (as I have done several times before) just binned the spring and the slider from the rotor centre. This then leaves the Hall Sender to do the rpm limit at 6500rpm approx.
==>PUGSPORT!<==
Wont be rev limiter, thats up near 6500 (trust me I've found it on occassion).... May be a faulty rotor arm, they work on centrifugal force which pulls back the contact at a specific rpm....
Simmo will prob have the answer as this is a known problem RE: kv engine at times. EDIT: Simmo beat me to it
thanks men, i think thats it!!
most likely wrong one then? hope so-will keep you posted |
Annnddd don't forget the fuel pump relay also has a rev limiter fitted into it's circuitry too. German and Swedish do the lot, I'd change them all to rule out a vacuum pipe braking down ( closing up ) under load / pressure. The KV runs critically on vacuum big time. If you need to know more then pm me and I'll go through the bits to look at and check.
| Vehicle speed-limiter systems loom | amanda | General Chat | 3 | 17-09-08 07:17 AM |
